[EMF Compare] Comparing 2 XML schemas [message #130183] |
Wed, 15 October 2008 05:30  |
I would like to know whether I can load and compare 2 xml schemas. I just
downloaded Eclipse Ganymede and tried loading 2 different Projects based
on 2 different sets of XML schemas. I wonder how can I diff between 2
models. Any idea?
Re: [EMF Compare] Comparing 2 XML schemas [message #620358 is a reply to message #130197] |
Sun, 19 October 2008 22:58  |
Thanks for the prompt response, laurent.
I have another question. Sorry for being a newbie here as I couldn't find
any help from the links you gave. Should I use the same project to compare
those different set of XML schemas or I can use different projects for
each XML schemas. I have 2 set of XML schemas (with different version, of
course) and I want to compare them to see the changes made for the same
structure e.g. new <element/> added for the similar <complexType/>.
In addition, can I compare these 2 sets of XML schemas programmatically
(without Eclipse)?
Zillion thanks,again.
laurent Goubet wrote:
> Hi Nazir,
> Comparing you XML schemas should be possible if you are able to load
> them within Eclipse. The Eclipse wiki page for EMF Compare (
> http://wiki.eclipse.org/index.php/EMF_Compare ) should provide you with
> all needed information. More specifically, take a look at
> http://wiki.eclipse.org/Comparing_XML_files_with_EMF_Compare and
> http://wiki.eclipse.org/EMF_Compare_FAQ .
> Regards
> Muhamad Nazir a écrit :
>> Hi,
>> just downloaded Eclipse Ganymede and tried loading 2 different Projects
>> based on 2 different sets of XML schemas. I wonder how can I diff
>> between 2 models. Any idea?
>> Thanks
FUDForum. Page generated in 0.09322 seconds
