Home » Modeling » GMF (Graphical Modeling Framework) » Custom Dialog for a certain type of Node
Custom Dialog for a certain type of Node [message #130149] Fri, 25 May 2007 06:38 Go to next message
Originally posted by: evaandoli.dodo.com.au
I'd like to create a custom dialog when a user adds a certains type of node
to the diagram.
I thought this had been asked before on here but I could not find the
entry - so sorry if it has.
Can anyone give me a few pointers on:-
1) Best way to create a custom dialog.
2) Where should this be plug into in the diagram setup ?
Thanks for any help,
Stu
Re: Custom Dialog for a certain type of Node [message #131216 is a reply to message #130149] Wed, 30 May 2007 10:53 Go to previous messageGo to next message
Originally posted by: fbanica.soluta.net
Me, for instance, I made a new action (for a menu voice in the pop-up menu)
and from the run method I create and open a dialog. Inside I put the
controls and the logic I needed...
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f36eat$fbj$1@build.eclipse.org...
> node to the diagram.
> Stu
Re: Custom Dialog for a certain type of Node [message #131340 is a reply to message #131216] Wed, 30 May 2007 23:43 Go to previous messageGo to next message
Its the "Inside (dialog) I put the controls and the logic I needed".
That Im not sure how to start.
I haven't created a custom dialog before and I find myseld running around
trying to find examples of how to (without much success).
Stu
"Florin Banica" <fbanica@soluta.net> wrote in message
news:f3k36u$cd4$1@build.eclipse.org...
> menu) and from the run method I create and open a dialog. Inside I put the
>> Hi,
>> Stu
Re: Custom Dialog for a certain type of Node [message #131382 is a reply to message #131340] Thu, 31 May 2007 03:37 Go to previous messageGo to next message
Here it is a small example of a dialog (including the action, a command
needed for modifying the GMF resource and some content and label providers
for a listview and a comboview).
The action is a contribution to the org.eclipse.ui.popupMenus extension
point:
<action
class=" net.soluta.factory05.negotiation.diagram.utils.CreateVariabl esAction "
enablesFor="1"
id=" net.soluta.factory05.negotiation.diagram.utils.CreateVariabl esActionID "
label="%createVariables"
menubarPath="additions">
</action>
Inside the CreateVariablesAction class, in it's run method you declare a
dialog variable:
VariablesDialog dialog = new VariablesDialog(shell, selection);
and then you just open it:
dialog.open();
You could also check the return code of open (it returns an int) and act in
consequence.
Inside the VariablesDialog class you will find how it is made (how controls
are declared and used) and how it's working.
There is a series of articles about this and related themes:
1. http://www.eclipse.org/articles/viewArticle/ViewArticle2.htm l
2.
http://www.eclipse.org/articles/Article-JFace%20Wizards/wiza rdArticle.html
3. http://www.eclipse.org/articles/Article-TreeViewer/TreeViewe rArticle.htm
Have a look at them and then try to make it on your own...
Hope it will help you make yourself an idea about the dialog and how it
works...
Good luck,
Floppy
news:f3lg9p$47j$1@build.eclipse.org...
> Stu
>> the
>>> Hi,
>>> Stu
Re: Custom Dialog for a certain type of Node [message #131710 is a reply to message #131382] Thu, 31 May 2007 21:29 Go to previous message
Excellent reply - thank you very much for this.
Stu
news:f3lu07$ao0$1@build.eclipse.org...
> point:
> <action
> enablesFor="1"
> </action>
> dialog variable:
> dialog.open();
> in consequence.
> controls are declared and used) and how it's working.
> 2.
> 3.
> works...
> Good luck,
> Floppy
>> Stu
>>> the
>>>> Hi,
>>>> Stu
Previous Topic:Resize automatically a Rectangle
Next Topic:OCL constraint
Current Time: Tue Jul 29 02:15:26 EDT 2025
Powered by FUDForum. Page generated in 0.08804 seconds
