Home » Modeling » GMF (Graphical Modeling Framework) » diagram editor 4 GMF ... exists?
diagram editor 4 GMF ... exists? [message #122553] Mon, 30 April 2007 09:24 Go to next message
Hi folks,
I'm new to GMF, but as soon as I started playing around with the GMF
tutorials I was wondering if there's no tool out there which makes
editing these *.gmfgraph / *.gmftool / *.gmfmap and *.gmfgen easier.
Maybe something similar to the ecore diagram editor for *.ecore files?
Another thing which bothers me is how to maintain changes in the
*.gmfgen file when changing other *.gmf* files.
With best regards
Stefan Kuhn
Re: diagram editor 4 GMF ... exists? [message #122566 is a reply to message #122553] Mon, 30 April 2007 10:33 Go to previous messageGo to next message
Hello SKuhn,
Try org.eclipse.gmf.graphdef.editor plugin from /cvsroot/modeling org.eclipse.gmf/plugins/org.eclipse.gmf.graphdef.editor
this is an experimental graphical editor for .gmfgraph model.
It should be possible to re-transform modified .gmfmap file to the same (existing)
..gmfgen.
Alex Shatalin
Re: diagram editor 4 GMF ... exists? [message #129547 is a reply to message #122566] Thu, 24 May 2007 11:04 Go to previous messageGo to next message
Dear Alex,
> same (existing) .gmfgen.
In GMF Best Practices from EcliseCon2k7 from you ;) I've read on the
last page
"Currently user can modify GMFGen model directly and will loose all
modifications on next transformation.
In future: we’d like to make .gmfmap -> .gmfgen transformation
extensible so user will be able to modify transformatrion code directly.
(Transformation should be realized not on Java)"
Did the future already arrive? =) Is there a way to really protect my
changes?
Thanks for your help
stefan
Alex Shatalin schrieb:
> Hello SKuhn,
> org.eclipse.gmf/plugins/org.eclipse.gmf.graphdef.editor this is an
> (existing) .gmfgen.
> Alex Shatalin
Re: diagram editor 4 GMF ... exists? [message #130121 is a reply to message #129547] Fri, 25 May 2007 06:02 Go to previous message
Hello SKuhn,
> changes?
Unfortunately not yet ;-( If you are talking about such a kind of changes
(not only tuning some properties, but altering the structure of genmodel)
then possible soluition for now is to extend existing .java gmfgen->.gmfmap
transformer and adjust it in accordance or manually apply your modification
after each transformation..
Alex Shatalin
Previous Topic:AbstractEMFOperation is not making the document dirty
Next Topic:Using Polygon as a parent figure.
Current Time: Wed Nov 12 05:22:16 EST 2025
Powered by FUDForum. Page generated in 0.05112 seconds
