Home » Modeling » TMF (Xtext) » Rule written for DSL in xtext, It is not working as expected(Rule written for DSL in xtext, It is not working as expected)
Rule written for DSL in xtext, It is not working as expected [message #1300171] Thu, 17 April 2014 07:31 Go to next message
I am trying -->> VL:'this is test dsl in xtext' IS ABC
TestLabelBase returns ResultExpressionRhs: 'VL:' path=stringRule;
The Rule I tried was: TestLabel returns ResultExpressionRhs: TestLabelBase ('IS' modifier=alphabateModifier)?;
alphabateModifier: (abc?='ABC' | def?='DEF' | ghi?='GHI');
It would recognize the 'IS' but not the 'ABC'.
Re: Rule written for DSL in xtext, It is not working as expected [message #1300369 is a reply to message #1300171] Thu, 17 April 2014 10:21 Go to previous messageGo to next message
can you please share a complete reproducable example
btw your grammar looks very complictated
Stuff:
'VL'':' label=STRING 'IS' (abc?='ABC' | def?='DEF' | ghi?='GHI');
Re: Rule written for DSL in xtext, It is not working as expected [message #1300605 is a reply to message #1300369] Thu, 17 April 2014 13:53 Go to previous messageGo to next message
Thanks for your interest.
xtext rule:
DSL Sample:
Problem is :
When I want to use ABC in dsl file at the end of statement , it does not allow it.
Re: Rule written for DSL in xtext, It is not working as expected [message #1300616 is a reply to message #1300605] Thu, 17 April 2014 14:01 Go to previous messageGo to next message
Hi, still cannot reproduce this,
e.g.: what is the start (first) rule of your grammar.
if it is TestLabelBase this is your mistake
Re: Rule written for DSL in xtext, It is not working as expected [message #1300639 is a reply to message #1300616] Thu, 17 April 2014 14:21 Go to previous messageGo to next message
I used following import "http://www.eclipse.org/emf/2002/Ecore" as ecore in xtext.
Below is my xtext file I am using:
DSLDEMO:
(messgae+=Message)*;
Message:
element+=ResultExpression+
Product:
'ProductName:' name=OptEscapeString '[' group=OptQuoteString ']'
ResultExpression:
Product rhs=ResultExpressionRhs;
ResultExpressionRhs returns ResultExpressionRhs:
(Product | TestLabel | StringLiteral);
alphabateModifier:
StringLiteral returns ResultExpressionRhs:
value=OptEscapeString;
enum PaoParamOperator:
ASSIGN='=';
OptQuoteString:
(OptEscapeString | STRING_UNQUOTED);
OptEscapeString:
(STRING_NOESCAPE | STRING_ESCAPE);
terminal NUMBER:
('0'..'9')* ('.' ('0'..'9')+)?;
terminal INT returns ecore::EInt:
'this one has been deactivated';
terminal STRING_UNQUOTED:
('a'..'z' | 'A'..'Z' | '0'..'9') ('a'..'z' | 'A'..'Z' | '0'..'9' | ' ' | '\\')+;
terminal STRING_NOESCAPE:
terminal STRING_ESCAPE:
'"' ('\\' ('b' | 't' | 'n' | 'f' | 'r' | 'u' | '"' | "'" | '\\') | !('\\' | '"'))* '"';
Re: Rule written for DSL in xtext, It is not working as expected [message #1300640 is a reply to message #1300639] Thu, 17 April 2014 14:23 Go to previous messageGo to next message
Hope now you will be able to understand.
Re: Rule written for DSL in xtext, It is not working as expected [message #1300670 is a reply to message #1300639] Thu, 17 April 2014 14:54 Go to previous messageGo to next message
hi, this is still not complete . stringRule is missing.
and the info if you use terminals grammar or not.
then you have way to many terminals,
including critical ones like string unquoted.
it contains a ' ' (blank)
xtext works with lexer and parser,
the lexing is eager.
generating the grammar (asuming
'VL:' path=STRING;)
gives a lot of ambiguity warnings
is this a existing language or a new one?
maybe you should start with an easier grammar
reusing the terminals defined in the terminal grammar
e.g:
NUMBER: INT? ('.' INT);
MY_STRING: STRING | (ID+);
stuff like 'this one has been deactivated'
is a bad idea (dont use blanks in strings)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Rule written for DSL in xtext, It is not working as expected [message #1301454 is a reply to message #1300670] Fri, 18 April 2014 01:31 Go to previous messageGo to next message
Sorry my mistake stringRule must be replaced by OptEscapeString.
Re: Rule written for DSL in xtext, It is not working as expected [message #1311169 is a reply to message #1300670] Wed, 23 April 2014 12:42 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 17 April 2014 14:54
generating the grammar (...) gives a lot of ambiguity warnings
Is possible to write a grammar that permits spaces in strings?
I have this problem: I need to write a grammar to load a OBO Flat File Format as an Ecore model. The OBOFFF has stanzas that are formatted as tag-value pairs that can be (or not) followed by modifiers (strings between brackets) and inline comments (string after an exclamation mark).
<tag>: <value> ['{'<modifier1>=<value1> ',' [<modifier2> '=' <value2>,...]'}'] ['!'<comment>]
The <value> part of the pair can be an ID (a unquoted string without whitespaces), a URI, a quoted string (whitespaces and escape characters allowed) or a unquoted string that should end at the end of the line or before the trailing modifiers/comment. Additionally, some values should use a combination of those strings, like:
subsetdef: GO_SLIM "GO SLIM"
I'd thought that I could write a rule to match it as
SubSetDefPair returns SubSetDefPair:
	tag='subsetdef:' WS_CHAR* subsetName=ID WS_CHAR description=QUOTED_STRING
terminal WS_CHAR :
	' ' | '\t'
terminal ID  : '^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
terminal QUOTED_STRING	:
	// A String that starts and ends with double quotation marks
\' ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') | !('\\'|'"') )* '"'
terminal UNBOUNDED_STRING:
// a string that should end at the ending of the line or before a comment
(('a'..'z'|'A'..'Z'|'_'|'0'..'9' | WS_CHAR)*
('a'..'z'|'A'..'Z'|'_'|'0'..'9'))?
[/code]
But it's not working.
I expected to match something like
subsetdef: asd "asdssd"
but it returns the following error:
Multiple markers at this line
- mismatched character '"' expecting set null
- mismatched character '<EOF>' expecting '"'
Does anyone have an idea of how I can address this issue?
Re: Rule written for DSL in xtext, It is not working as expected [message #1311207 is a reply to message #1311169] Wed, 23 April 2014 13:12 Go to previous messageGo to next message
just one thing: not every thing must be in the grammar. you can write semantic checks/validations in java/Xtend too
Re: Rule written for DSL in xtext, It is not working as expected [message #1311267 is a reply to message #1311207] Wed, 23 April 2014 14:00 Go to previous messageGo to next message
Humm... This is something I still don't understand quite well how to do (or when I should do). What's the recommended documentation (or some example) about it?
Re: Rule written for DSL in xtext, It is not working as expected [message #1311298 is a reply to message #1311267] Wed, 23 April 2014 14:24 Go to previous message
its in the docs, http://www.eclipse.org/Xtext/documentation.html#validation
searching for XText + Validator/Check should give many results
Previous Topic:generate property from referenced object
Next Topic:reference whitespace issue
Current Time: Wed Jul 23 12:35:29 EDT 2025
Powered by FUDForum. Page generated in 1.60722 seconds
