Home » Eclipse Projects » Eclipse 4 » Behavior Differences Between @Active and @Named(Behavior differences between @Active and @Named)
Behavior Differences Between @Active and @Named [message #1298822] Wed, 16 April 2014 10:29 Go to next message
eclipse.buildId=4.3.2.M20140221-1700
CentOS 2.6.32-358.23.2.el6.x86_64
We have a RCP app that we've been nursing along as e4 evolves. In this RCP app we have some parts with toolbars, and on those toolbars there is a pushbutton that eventually makes its way to a handler whose execute method used to look like this:
@Execute
public void execute(
@Named(IServiceConstants.ACTIVE_SHELL) Shell shell,
@Named(IServiceConstants.ACTIVE_PART) MPart part
I expected that when we clicked the aforementioned toolbar button that the "part" argument would be the part on which the toolbar was located, but sometimes it is some other part. I haven't yet been able to pin down a pattern regarding which part shows up in this argument.
However...
If we change the execute method so it looks like this:
@Execute
@Active MPart part
...then so far everything has worked just like I expect, i.e. the "part" argument is always the part associated with the toolbar whose button was clicked.
Is this a feature?
Rob
Re: Behavior Differences Between @Active and @Named [message #1299951 is a reply to message #1298822] Thu, 17 April 2014 04:13 Go to previous messageGo to next message
> @Execute
This would be that the part with the toolbar is not activated
appropriately before the toolbars action is exectued with sounds like a bug!
> However...
> @Execute
> @Active MPart part
To understand the difference between @Activte and ACTIVE_* you should
maybe read my blog http://tomsondev.bestsolution.at/2013/01/30/active-in-e4/
I generally think in your case the you don't need any of the above but
public void execute(@Named(IServiceConstants.ACTIVE_SHELL) Shell shell,
MPart part)
should be fine.
Tom
Re: Behavior Differences Between @Active and @Named [message #1302161 is a reply to message #1299951] Fri, 18 April 2014 11:02 Go to previous message
Sounds like Alex and I were asking similar questions. One thing is clear: the fact that I made this mistake means I need to take a step back and study the context hierarchy some more.
>> MPart part)
>> should be fine.
Yep - that worked too.
Thanks for the help!
Rob
Previous Topic:tooltip of handled tool item
Next Topic:How do i define and use my own renderer?
Current Time: Sun Jul 27 10:58:17 EDT 2025
Powered by FUDForum. Page generated in 0.04149 seconds
