Home » Modeling » TMF (Xtext) » How can I generate code from my XText DSL without IDE?
How can I generate code from my XText DSL without IDE? [message #1297022] Tue, 15 April 2014 07:13 Go to next message
I would like generate my C++ code from my own dsl without IDE. Inside Eclipse IDE everthing is fine. I can also build my CDT project (headlessbuild) but the xtext/xtend generation is missing.
Any ideas?
Thanks Simon
Re: How can I generate code from my XText DSL without IDE? [message #1297121 is a reply to message #1297022] Tue, 15 April 2014 08:39 Go to previous messageGo to next message
Hi Simon,
In http://lwc11-xtext.eclipselabs.org.codespot.com/files/LWC11-XtextSubmission-v1.2.pdf on page 130 (14.2 Headless Generator) there is an example how to do this in pure Java. Alternatively and the more preferred way you can also write a mwe2 file and load and start this from command line.
With
fragment = generator.GeneratorFragment auto-inject {
     generateMwe = true
in the language generation workflow you can pregenerate a workflow file executing the generator of your DSL.
Joerg
Re: How can I generate code from my XText DSL without IDE? [message #1297133 is a reply to message #1297121] Tue, 15 April 2014 08:47 Go to previous messageGo to next message
Thank you, Joerg.
Simon
Re: How can I generate code from my XText DSL without IDE? [message #1298881 is a reply to message #1297133] Wed, 16 April 2014 11:22 Go to previous messageGo to next message
One thing I forgotten to mention was, that there is the org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner. With that you can execute mwe2 files.
Joerg
Re: How can I generate code from my XText DSL without IDE? [message #1299850 is a reply to message #1298881] Thu, 17 April 2014 02:43 Go to previous messageGo to next message
Thanks Joerg!
One question about the workflow.
I have a workspace/project for my DSL implementation, code generation ...
Now I will starting a runtime eclipse.
The dsl editor works fine, code genaration also.
I have also generated the mwe2 file. ( bin directory in the dsl impl. project)
Now, how can I call the generation on the command line?
./eclipse -nosplash org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner  -data "/home/simonz/dev/runtime-EclipseXtext"
This will be not working!?
Thanks Simon
Re: How can I generate code from my XText DSL without IDE? [message #1299912 is a reply to message #1299850] Thu, 17 April 2014 03:36 Go to previous message
Hi Simon,
you don't need to start Eclipse.
This a little example:
public class Main {
		Injector injector = new Mwe2StandaloneSetup().createInjectorAndDoEMFRegistration();
		Mwe2Runner runner = injector.getInstance(Mwe2Runner.class);
		URI createURI = URI.createFileURI("src/org/xtext/example/mydsl/generator/MyDslGeneratorMWE.mwe2");
		Map<String, String> params = new HashMap<String, String>();
		params.put("modelPath", "samples/");
		params.put("targetDir", "output");
		runner.run(createURI, params);
As an alternative, you even can pre-generate a Main class by using this snippet in the grammar mwe2 file:
	generateMwe = true
	generateJavaMain = true
This code doesn't use the Mwe2Runner and takes only one resource as input but you may adapt this to your needs as well.
Joerg
Previous Topic:xText allows to create a Prolog Parser?
Next Topic:Xtend JUnit test in domainmodel example stop running
Current Time: Wed Jul 23 17:04:29 EDT 2025
Powered by FUDForum. Page generated in 0.04477 seconds
