Home » Eclipse Projects » GEF » z order
z order [message #129678] Thu, 29 April 2004 08:09 Go to next message
all,
i am looking for a good example of re-ordering children to create the
"send backwards/send to back/bring forwards/bring to front" type z order
support.
the "send to back" and "bring to front" seem like simple things since they
would just be the beginning and end of the children list, but "send
backwards" and "bring forwards" require you to know all the figures the
selected figure is touching. how do you do this?
thanks in advance,
steve
Re: z order [message #129734 is a reply to message #129678] Thu, 29 April 2004 11:45 Go to previous messageGo to next message
I did this by changing the order of the model objects. I think GEF
refreshes the order of the figures based on the order of the model. I got
the model object from the selection and created a command to move it
accordingly. Worked fine for me. :)
Good-luck!
"Steven Melzer" <smelzer@paymentech.com> wrote in message
news:c6qrab$s5d$1@eclipse.org...
> all,
> support.
> thanks in advance,
> steve
Re: z order [message #129805 is a reply to message #129734] Thu, 29 April 2004 11:53 Go to previous messageGo to next message
jody (and all),
thanks for the fast feedback. but i do not believe i was clear. let me
give an example:
i have 3 figures on my display: call them A, B, and C. when they are
added to the model, they show up on the display fine. when you put them
near each other, they overlap each other. so, you see half of A, part of
B, and all of C.
i want to move C back. there are two options: "send to back" and "send
backwards". "send to back" will put C as the first item in the child list
and give him the lowest Z-order on the display. but "send backwards"
should just send C behind A and B because they are touching it, but not
make it the first child on the display. this gives C priority over over
things that may get moved or added later.
my problem is how to determine when C is selected, that it is touching A
and B.
thoughts?
thanks,
steve
> Good-luck!
> > all,
> > support.
> > thanks in advance,
> > steve
Re: z order [message #129855 is a reply to message #129805] Thu, 29 April 2004 15:15 Go to previous messageGo to next message
Did you try using Rectangle.intersects() to see if the bounds of A, B and C
intersect?
news:c6r8dh$egl$1@eclipse.org...
> jody (and all),
> give an example:
> B, and all of C.
> and B.
> thoughts?
> thanks,
> steve
got
> > Good-luck!
> > > all,
order
> > > support.
they
the
> > > thanks in advance,
> > > steve
Re: z order [message #130321 is a reply to message #129855] Mon, 03 May 2004 22:33 Go to previous message
i will try this. thanks.
steve
> intersect?
> > jody (and all),
> > give an example:
> > B, and all of C.
> > and B.
> > thoughts?
> > thanks,
> > steve
> got
> > > Good-luck!
> > > > all,
> order
> > > > support.
> they
> the
> > > > thanks in advance,
> > > > steve
Previous Topic:pixel , measurment units -again
Next Topic:Spacing BlockFlows
Current Time: Fri Sep 19 05:55:21 EDT 2025
Powered by FUDForum. Page generated in 0.04667 seconds
