Home » Eclipse Projects » Eclipse 4 » tooltip of handled tool item
tooltip of handled tool item [message #1295698] Mon, 14 April 2014 09:55 Go to next message
I do have a part with a toolbar and some handled tool item in there.
Bound to a command and so to a handler the tool items become disabled or
enabled depending on the canExecute-method of the handlers. So
everything is fine. But when an item is disabled I do want to let the
user know why it is disabled.
My thought lead me to the tooltips of the handled tool items but I do
not know how to access them.
What can I do?
Greetings,
Jan
Re: tooltip of handled tool item [message #1296774 is a reply to message #1295698] Tue, 15 April 2014 03:26 Go to previous messageGo to next message
@CanExecute
public boolean ce(..., MHandledItem item){
boolean isEnabled;
item.setToolTip(isEnabled?"YES":"NO");
return isEnabled;
Re: tooltip of handled tool item [message #1297436 is a reply to message #1296774] Tue, 15 April 2014 13:26 Go to previous messageGo to next message
Thanks, this might work.
But is there no more elegant way? It seems to me I would break the loose
coupling between the handler and the ui element when I use the ui
element directly...
Am 15.04.2014 09:26, schrieb Sopot Cela:
> @CanExecute
> boolean isEnabled;
> return isEnabled;
Re: tooltip of handled tool item [message #1298400 is a reply to message #1297436] Wed, 16 April 2014 04:31 Go to previous messageGo to next message
You want to access the tooltip of the item without accessing the item?
Re: tooltip of handled tool item [message #1298556 is a reply to message #1298400] Wed, 16 April 2014 06:53 Go to previous messageGo to next message
I want a way to tell the user why an ui action can't be executed by him.
The tooltip was just a thought (yes I know poor title of the posting
then). At least there should be such thing as returning an IStatus
instead of a boolean value from @CanExecute. You know what I mean?
I mean it goes a long way of abstractions down to the handler and back
to tell whether an ui action can be executed or not. But grabbing the ui
element and using it directly breaks the abstraction chain and that
feels not right for me. You know?
Am 16.04.2014 10:31, schrieb Sopot Cela:
Re: tooltip of handled tool item [message #1298564 is a reply to message #1298556] Wed, 16 April 2014 06:57 Go to previous messageGo to next message
So you'd like the @CanExecute to return an IStatus instead of a simple
boolean?
Tom
Re: tooltip of handled tool item [message #1298612 is a reply to message #1298564] Wed, 16 April 2014 07:31 Go to previous message
I think it would be a nice solution for my request if the message would
be delivered to and interpreted by the corresponding items.
Jan
Am 16.04.2014 12:57, schrieb Tom Schindl:
> boolean?
> Tom
Previous Topic:Dependency Injection (Beginner)
Next Topic:Behavior Differences Between @Active and @Named
Current Time: Sun Jul 20 21:25:40 EDT 2025
Powered by FUDForum. Page generated in 0.07552 seconds
