Home » Newcomers » Newcomers » Help required to decide the IDE(Help required to decide the IDE)
Help required to decide the IDE [message #1296469] Mon, 14 April 2014 22:32 Go to next message
HI guys,
Please help me in deciding the right eclipse version for the below mentioned requirement. I am looking for some IDE which can replace RAD(ofcourse the reason is budget). either free or something cheaper than RAD.
1) Spring MVC portlet
2) Target Runtimes: Websphere portal server 8, WAS 8.5
3) Maven Integration
4) CVS/SVN support
5) Integration with some code review tool like SONAR
6) Angular Js support
Appreciate your help..
[Updated on: Tue, 15 April 2014 12:29] by Moderator
Re: Help required to decide the IDE [message #1297772 is a reply to message #1296469] Tue, 15 April 2014 18:31 Go to previous messageGo to next message
On 04/15/2014 07:30 AM, Harin JY wrote:
> HI guys,
> than RAD.
> 2) Target Runtime: Websphere portal server 8. But we are not planning to
> test in local. Just, i need to create a war file which can be deployed
> in WPS8 server.
> 4) CVS Integration
Eclipse will give you all of that, but Spring Source Toolsuite
(http://spring.io/tools/sts) is free, I think, and built atop Eclipse.
Try that if you like.
Otherwise, there's nothing stopping you from using Eclipse IDE for Java
EE Developers and Spring JAR libraries.
I'm not a Websphere guy; you might ask advice in the Eclipse WTP forum.
Best of luck.
Re: Help required to decide the IDE [message #1298935 is a reply to message #1297772] Wed, 16 April 2014 12:09 Go to previous message
Thanks Russell. If i get a solution, i will post it here..
Previous Topic:Eclipse can't access internet
Next Topic:Eclipse stopped starting after Ubuntu 13.04 update
Current Time: Mon Jul 21 02:32:55 EDT 2025
Powered by FUDForum. Page generated in 0.32138 seconds
