Home » Eclipse Projects » Eclipse 4 » Dependency Injection (Beginner)(Difference between IEclipseContext.set and ContextInjectionFactory.make)
Dependency Injection (Beginner) [message #1295411] Mon, 14 April 2014 04:44 Go to next message
could anyone please tell me whats the difference between:
IEclipseContext.set and ContextInjectionFactory.make?
Thank you!
Re: Dependency Injection (Beginner) [message #1295591 is a reply to message #1295411] Mon, 14 April 2014 07:56 Go to previous messageGo to next message
CIF#make(Class, Context) creates and returns an instance of class 'Class'. If the class in question requires to be injected with some objects (has an @Inject constructor, field or @Execute method etc.) it uses the context 'Context' to look up (resolve) the objects to inject. Plainly speaking, it creates an object in a given context. That matters because the resolved injection objects can be different in different contexts. CIF#make doesn't put this newly created object in the 'Context' context.
IEC#set(K,V) just sets an *already* created object 'V' to a context with some arbitrary key 'K'. No object creation or injection resolving involved.
Re: Dependency Injection (Beginner) [message #1295603 is a reply to message #1295591] Mon, 14 April 2014 08:06 Go to previous messageGo to next message
Okay thank you I think I've got it now!
So the ContextInjectionFactory is just used because a new operator would not support Injection, right?
Re: Dependency Injection (Beginner) [message #1295604 is a reply to message #1295603] Mon, 14 April 2014 08:08 Go to previous messageGo to next message
Right.
Re: Dependency Injection (Beginner) [message #1295634 is a reply to message #1295604] Mon, 14 April 2014 08:44 Go to previous message
I've got one more question on my mind..
In the documentation of the CIF I read the following:
"Class'es scope dictates if a new instance of the class will be created, or existing instance will be reused."
Does this mean, that if there is an object already assigned to the variable and i reassign it with CIF,
that I could get different behavior than to assign it to a new variable?
Previous Topic:How can I include custom controls in Application.e4xmi?
Next Topic:tooltip of handled tool item
Current Time: Wed Jul 23 11:49:59 EDT 2025
Powered by FUDForum. Page generated in 0.07308 seconds
