| Eclipes deleted my files. HELP!!! [message #129409] |
Thu, 12 January 2006 15:18  |
Originally posted by: tsullivan.tps-software.com
I had a java project in eclipse. I attempted to rename the project. The
rename process failed. The contents of that project are now gone. Would
someone PLEASE help me get my data back?
Why would ANY software delete files BEFORE copying them to the new
location????
| Re: Eclipes deleted my files. HELP!!! [message #130910 is a reply to message #130538] |
Fri, 20 January 2006 15:12   |
Actually, to test this functionality, I imported a project, attempted to
rename the project (I made it fail the same as before), and then I tried
to do the "Restore From Local History...".
This feature isn't really going to help me much anyway. I've been redoing
the last month and a half of work for the past week already. It's easier
to remake than it is to invent from scratch.
The main point is, the "Rename" process should not be deleting files
before they are moved or copied over to the new name/location. This is a
very BAD thing to do. Solution: if you can't just rename the project
without removing the contents first, then create a NEW project by the NEW
name, move/copy the contents and then remove the old project. Safe,
sound, logical. If it fails for some reason in the middle, nothing is
lost. At the very worst files could be misplaced. That is A LOT easier
to recover from that GONE.
| Re: Eclipes deleted my files. HELP!!! [message #130923 is a reply to message #130910] |
Fri, 20 January 2006 15:51   |
> redoing the last month and a half of work for the past week already.
> It's easier to remake than it is to invent from scratch.
> a very BAD thing to do. Solution: if you can't just rename the project
> NEW name, move/copy the contents and then remove the old project. Safe,
OK, I did a test to try to reproduce, but it behaved quite reasonably
and no files were lost. Here's a screencast:
http://www.rizzoweb.com/Eclipse/RenameProject.html
Please tell us how this differs from what you did or observed. Also,
what version of Eclipse are you using?
Eric
| Re: Eclipes deleted my files. HELP!!! [message #132242 is a reply to message #131675] |
Thu, 26 January 2006 18:16  |
Ted Sullivan wrote:
> OK! I've narrowed it down to some IBM plug-ins that seem to be causing
> problems. I'll take this up with them. Thank you SO MUCH for your
> assistance.
You're welcome, but please share with the group which plugins you find
problems with, if/when you narrow it down.
Eric
FUDForum. Page generated in 0.11089 seconds
