Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT 4.3 browser displays IE 11 incorrectly(SWT 4.3 browser displays IE 11 incorrectly)
SWT 4.3 browser displays IE 11 incorrectly [message #1292095] Fri, 11 April 2014 10:07 Go to next message
I display html pages in SWT browser. I'm interested in IE 11. External browser displays everything correctly. But internal browser does not (width of droplist shotter than it should be in combobox).
I know that there is the bug about ie version in windows registry (9.11.9600.16428 instead of 11.0.9600.16428), and i manually corrected version in registry (HKEY_LOCAL_MACHINE\Software\Internet Explorer\Version).
So i think that swt browser uses IE11 mode.
When IE8 was installed on my computer everething worked correctly. The problem appeared since i have installed IE11.
i'm using jdk 1.6, windows 7 x64, IE 11, SWT 4.3.
Re: SWT 4.3 browser displays IE 11 incorrectly [message #1295242 is a reply to message #1292095] Mon, 14 April 2014 01:33 Go to previous messageGo to next message
Hi Olga,
There was a recent bug fix in SWT 4.4M3 w.r.t. IE10,IE11 browser compatibility: https://bugs.eclipse.org/bugs/show_bug.cgi?id=404543
Suggest you to try any of the latest releases of Eclipse/SWT(version 4.4M3 & above), same you can download from below:
http://download.eclipse.org/eclipse/downloads/index.html
Niraj
Re: SWT 4.3 browser displays IE 11 incorrectly [message #1295780 is a reply to message #1295242] Mon, 14 April 2014 11:26 Go to previous message
Hi Niraj,
thank you for your answer.
I saw that commit, but it couldn't help me. Eclipse developers changed field they get ie version. But it's not a problem. I understood that no matter which version swt browser took. Html combobox shoul be displayed correctly in any ie version.
I attached screen with combobox. Html code:
<tr>
<td>Согласие</td>
<td>
<select style="width: 100%;">
<option>да</option>
<option>нет</option>
<option>&nbsp;</option>
</select>
</td>
</tr>
Thanks.
  • Attachment: 123.PNG
    (Size: 2.50KB, Downloaded 287 times)
[Updated on: Mon, 14 April 2014 11:27] by Moderator
Previous Topic:Accessibility problems in file dialog
Next Topic:Java 7 update 55 Mac broken
Current Time: Sat Jul 26 00:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.03633 seconds
