Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses
[EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1287541] Mon, 07 April 2014 18:10 Go to next message
My application needs to work over a cellular network where bandwidth is
quite constrained, so I'd like to be able configure the XML-RPC layer to
use GZIP compression.
Based on the instructions from the Apache XML-RPC site
(http://ws.apache.org/xmlrpc/client.html), I tried setting the XML-RPC
config in
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.
initConnection() by adding these two lines:
config.setGzipCompressing(true); config.setGzipRequesting(true);
but that ended with exceptions on both the client and server. Is it
possible to turn on compression for EMFStore requests and responses? If
so, how?
First the server exception:
Apr 07, 2014 5:33:49 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
SEVERE: Failed to read XML-RPC request: Invalid byte 1 of 1-byte UTF-8
sequence.
org.apache.xmlrpc.XmlRpcException: Failed to read XML-RPC request:
Invalid byte 1 of 1-byte UTF-8 sequence.
at
org.apache.xmlrpc.server.XmlRpcStreamServer.getRequest(XmlRpcStreamServer.java:73)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.execute(XmlRpcStreamServer.java:199)
at org.apache.xmlrpc.webserver.Connection.run(Connection.java:208)
at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
Caused by:
com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException:
at
com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.invalidByte(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.arrangeCapacity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipString(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown
Source)
at
org.apache.xmlrpc.server.XmlRpcStreamServer.getRequest(XmlRpcStreamServer.java:65)
... 3 more
Caused by:
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
at
And here is the client exception:
org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException:
Server could not be reached.
Failed to read XML-RPC request: Invalid byte 1 of 1-byte UTF-8 sequence.
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.executeCall(XmlRpcClientManager.java:168)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcClientManager.callWithResult(XmlRpcClientManager.java:114)
at
org.eclipse.emf.emfstore.internal.client.model.connectionmanager.xmlrpc.XmlRpcConnectionManager.logIn(XmlRpcConnectionManager.java:61)
at
org.eclipse.emf.emfstore.internal.client.model.impl.UsersessionImpl.logIn(UsersessionImpl.java:590)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl$5.doRun(ESServerImpl.java:227)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack$1.doExecute(EMFStoreTransactionalCommandStack.java:61)
at
org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at
org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.basicExecute(EMFStoreTransactionalCommandStack.java:163)
at
org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at
org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.runEMFStoreCommand(EMFStoreTransactionalCommandStack.java:64)
at
com.humanfactor.emf.edocument.editingdomain.EMFStoreTransactionalCommandStack.execute(EMFStoreTransactionalCommandStack.java:49)
at
org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at
org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
at
org.eclipse.emf.emfstore.internal.client.model.impl.api.ESServerImpl.login(ESServerImpl.java:236)
at
com.humanfactor.rw.timing.simulation.ui.TimerSimulation.setup(TimerSimulation.java:201)
at
com.humanfactor.rw.timing.simulation.SimulationClient.runSimulation(SimulationClient.java:88)
at
com.humanfactor.rw.timing.simulation.ui.action.RunSimulationAction.run(RunSimulationAction.java:25)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499)
at
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at
com.humanfactor.rw.timing.simulation.ui.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.apache.xmlrpc.XmlRpcException: Failed to read XML-RPC
at
at
Caused by:
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
Source)
at
... 3 more
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1291795 is a reply to message #1287541] Fri, 11 April 2014 04:13 Go to previous messageGo to next message
Hi Scott,
there is a similar class on the server side: XmlRpcWebserverManager
I guess you could configure the XML-RPC layer there to also use
compression on the receiving end and it should work then.
I would be happy to accept a contribution to make both configurations
API also.
Hope this helps!
Maximilian
Am 08.04.2014 00:10, schrieb scott@xxxxxxxx:
> config in
> so, how?
> sequence.
> at
> at
> Caused by:
> at
> at
> com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
> at
> Source)
> at
> Source)
> at
> ... 3 more
> Caused by:
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> ... 3 more
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1295896 is a reply to message #1291795] Mon, 14 April 2014 13:18 Go to previous messageGo to next message
After some investigation, it turns out that the simple XML-RPC WebServer
implementation that EMFStore is based on doesn't support gzip
compression. I traced it down to
org.apache.xmlrpc.webserver.Connection.getRequestConfig(), which doesn't
have the logic needed to extract the request data (Content-Encoding
header) telling the server whether the request is gzipped or not --- or
whether the response back to the client should be gzipped
(Accept-Encoding header). Perhaps there are others parts missing, too,
but I didn't check.
XML-RPC supports compression if it's deployed into a standard web
container using XmlRpcServlet or using XmlRpcServletServer. Moving from
the WebServer-based to XmlRpcServlet-based implementation is a bit too
much for me given my limited understanding of EMFStore server internals.
How difficult would it be to migrate to XmlRpcServer or XmlRpcServletServer?
One possible way forward is to compress/uncompress the message payloads
in the EObjectSerializer and EObjectTypeParser. I inserted a few lines
of code in both of these classes and the results are promising. Typical
commits include several changes my log file shows around 20:1
compression ratio for change package payloads. Here's a typical change
payload:
Bytes before uncompress = 3185
Bytes after uncompress = 62736
Sounds like a good approach?
$cott
On 4/11/2014 4:13 AM, Maximilian Koegel wrote:
> Hi Scott,
> API also.
> Hope this helps!
> Best regards,
> Maximilian
>> config in
>> so, how?
>> sequence.
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 3 more
>> Caused by:
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> ... 3 more
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1296931 is a reply to message #1295896] Tue, 15 April 2014 05:54 Go to previous messageGo to next message
Yes, this is a good idea! If this works it could be a nice contribution,
but it should be configurable somehow, since I would not like to change
the default at this time.
Maximilian
Am 14.04.2014 19:18, schrieb scott@xxxxxxxx:
> but I didn't check.
> payload:
> $cott
>> Hi Scott,
>> API also.
>> Hope this helps!
>> Best regards,
>> Maximilian
>>> config in
>>> so, how?
>>> sequence.
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> ... 3 more
>>> Caused by:
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> ... 3 more
Maximilian Kögel
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1297077 is a reply to message #1296931] Tue, 15 April 2014 07:56 Go to previous messageGo to next message
Great. I agree it should be configurable and the default should be no
compression. For configuration here are two options:
1. Extension point
org.eclipse.emf.emfstore.common.model.serializationOptions
2. A new variable and method in Configuration.getXMLRPC()
In the first option serialization options would need to be shared across
both EObjectSerializer and EObjectTypeParser. Today only
EObjectSerializer uses these options. Also, a reboot of the server and
client would be required to change the setting.
In the second option compression could be turned off and on dynamically.
Which do you prefer? Or maybe you prefer another place for this
configuration info. Let me know.
If you ever intend on moving the code base to support
XmlRpcServletServer, then adding these two additional variables and
methods would make compression a client-side decision w/o having to
configure the server:
1. Configuration.getXMLRPC().isXmlRPCGzipCompressing()
2. Configuration.getXMLRPC().isXmlRPCGzipRequesting()
Scott
> Cheers,
> Maximilian
>> but I didn't check.
>> payload:
>> $cott
>>> Hi Scott,
>>> API also.
>>> Hope this helps!
>>> Best regards,
>>> Maximilian
>>>> config in
>>>> so, how?
>>>> sequence.
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> ... 3 more
>>>> Caused by:
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> ... 3 more
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1297187 is a reply to message #1297077] Tue, 15 April 2014 09:38 Go to previous messageGo to next message
Here are the core changes to EObjectSerializer and EObjectTypeParser:
Changes in EObjectTypeParser:
In EObjectTypeParser.getResult() insert 7 lines of code:
InputStream bais;
if (useCompression()) {
logCompressionStats(res);
bais = new GZIPInputStream(new ByteArrayInputStream(res));
} else {
bais = new ByteArrayInputStream(res);
between these two lines of code:
final byte[] res = (byte[]) super.getResult();
reader = new BufferedReader(new InputStreamReader(bais,
CommonUtil.getEncoding()));
And add these three methods (logging methods just in case you need them):
private boolean useCompression() {
return true;
private void logCompressionStats(byte[] compressedByteArray) throws
IOException {
final byte[] uncompressedByteArray =
decompressGzipByteArray(compressedByteArray, 1024);
final double compressionRatio = new
Double(uncompressedByteArray.length) / compressedByteArray.length;
final DecimalFormat df = new DecimalFormat("#.#");
System.out.println("Uncompressed from " + compressedByteArray.length +
" --> " + uncompressedByteArray.length
+ " bytes. Compression ratio = " + df.format(compressionRatio) + ":1");
private byte[] decompressGzipByteArray(byte[] compressedByteArray, int
bufferlength)
throws IOException {
final ByteArrayOutputStream uncompressedStream = new
ByteArrayOutputStream();
final GZIPInputStream compressedStream = new GZIPInputStream(new
ByteArrayInputStream(compressedByteArray));
final byte[] buffer = new byte[bufferlength];
int index = -1;
while ((index = compressedStream.read(buffer)) != -1) {
uncompressedStream.write(buffer, 0, index);
return uncompressedStream.toByteArray();
Changes in EObjectSerializer
In EObjectSerializer.write() insert:
BufferedOutputStream bos;
bos = new BufferedOutputStream(new GZIPOutputStream(ostream));
} else {
bos = new BufferedOutputStream(ostream);
after this line:
final OutputStream ostream = new EncoderOutputStream(encoder);
And add this method:
return true;
When you decide how to configure compression, update the
useCompression() methods.
FYI, here's the complete set of decompressions for a commit in my
application:
Uncompressed from 198 --> 283 bytes. Compression ratio = 1.4:1
Uncompressed from 182 --> 293 bytes. Compression ratio = 1.6:1
Uncompressed from 236 --> 356 bytes. Compression ratio = 1.5:1
Uncompressed from 3282 --> 65115 bytes. Compression ratio = 19.8:1
Uncompressed from 245 --> 371 bytes. Compression ratio = 1.5:1
!ENTRY org.eclipse.emf.emfstore.common.model 1 1 2014-04-15 09:07:16.247
!MESSAGE Total time for commit: 758
Scott
> 1. Extension point
> Scott
>> Cheers,
>> Maximilian
>>> but I didn't check.
>>> payload:
>>> $cott
>>>> Hi Scott,
>>>> API also.
>>>> Hope this helps!
>>>> Best regards,
>>>> Maximilian
>>>>> bandwidth is
>>>>> layer to
>>>>> config in
>>>>> responses? If
>>>>> so, how?
>>>>> sequence.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> ... 3 more
>>>>> Caused by:
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> sequence.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> Source)
>>>>> at
>>>>> ... 3 more
Re: [EMFStore] Feature request: ability to configure compression for XML-RPC requests and responses [message #1311024 is a reply to message #1297187] Wed, 23 April 2014 10:53 Go to previous message
Hi Scott,
first of all, sorry for delay, we all were on holidays.
The changes you made look good. Regarding the configuration:
I think on the server side the compression method should be specified
within the es.properties file, since this file contains all relevant
server configuration options, whereas the client could use the
serializationOptions extension point.
Did you test this with a server that does not support compression
(option turned off) and a client sending a compressed request (option
turned on) and vice versa?
Also, would you mind opening a bug report for your changes and attaching
them as a patch (see
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFStore)?
Thanks for your work so far!
Edgar
Am 15.04.2014 15:38, schrieb scott@xxxxxxxx:
> InputStream bais;
> } else {
> return true;
> IOException {
> + " --> " + uncompressedByteArray.length
> bufferlength)
> int index = -1;
> } else {
> after this line:
> return true;
> application:
> Scott
>> 1. Extension point
>> Thanks,
>> Scott
>>> Cheers,
>>> Maximilian
>>>> WebServer
>>>> doesn't
>>>> but I didn't check.
>>>> internals.
>>>> payload:
>>>> $cott
>>>>> Hi Scott,
>>>>> API also.
>>>>> Hope this helps!
>>>>> Best regards,
>>>>> Maximilian
>>>>>> bandwidth is
>>>>>> layer to
>>>>>> XML-RPC
>>>>>> config in
>>>>>> responses? If
>>>>>> so, how?
>>>>>> log
>>>>>> UTF-8
>>>>>> sequence.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> ... 3 more
>>>>>> Caused by:
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> sequence.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> ... 3 more
Edgar Mueller
Previous Topic:[EMF Client Platform] Multi-Page Editor
Next Topic:[ECP] Support for Non XMI File Extensions
Current Time: Fri Jul 25 23:35:50 EDT 2025
Powered by FUDForum. Page generated in 0.13625 seconds
