Home » Eclipse Projects » Remote Application Platform (RAP) » Session timeout error
Session timeout error [message #128778] Mon, 20 April 2009 06:38 Go to next message
Hi everyone!
We use RAP for the UI part of our project and I'm experiencing some
strange session-timeout behaviour. When accessing the RAP servlet url with
a trailing slash ("/myproject/"), the first ajax request from the initial
HTML page (*):
" w4t_survey=true&w4t_scriptEnabled=true&w4t_ajaxEnabl ed=true&startup=default&w4t_width=1280&w4t_heigh t=453
&9012615=603%2C13&30501214=785%2C20&12433070=546 %2C12&w1.bounds.width=1280&w1.bounds.height=453& uiRoot=w1 "
runs ok, resulting javascript response that renders the login page just
fine. Then the secong request is performed:
" w12.mode=maximized&20627169=53%2C20&w1.focusControl= w11&uiRoot=w1&requestCounter=3 "
which results the response, containing the initial HTML of the page again!
So the Request.js _handleCompleted() sees the response content starting
with the "<!DOCTYPE" and displays the session timeout message, providing a
link to the same "/myproject/" page.
That's weird, but it works just fine when accessing the URL w/o the slash
- "/myproject".
What could cause such a behavior?
Thanks!
Alexander Eliseyev
Re: Session timeout error [message #129102 is a reply to message #128778] Tue, 21 April 2009 06:51 Go to previous messageGo to next message
Hi Alexander,
Apparently, RAP cannot deal with the trailing slash, you need to use the
correct URL which is http://host:port/myproject in your case - without a
trailing slash. Most web servers redirect silently, so the two URLs
might be perceived equivalent, but in fact there aren't.
However, I agree that RAP behaves strangely here, as the first request
succeeds, but then the seconds one fails - because of a falsely arranged
URL. Would you mind opening a bug report for this problem?
If you're using an Apache based setup, you could probably work around
this using some redirection magic there.
Best regards, Ralf
> Hi everyone!
> with a trailing slash ("/myproject/"), the first ajax request from the
> initial HTML page (*):
> again! So the Request.js _handleCompleted() sees the response content
> starting with the "<!DOCTYPE" and displays the session timeout message,
> providing a link to the same "/myproject/" page.
> slash - "/myproject".
> Thanks!
> Best regards,
> Alexander Eliseyev
Re: Session timeout error [message #129323 is a reply to message #129102] Wed, 22 April 2009 02:13 Go to previous message
Hi Ralf!
Thanks for the reply, I've created a bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=273184
Alexander
Previous Topic:External UIThread access
Next Topic:Anyone Ported the Nebula-PShelf-API to RAP
Current Time: Wed Jul 23 12:53:50 EDT 2025
Powered by FUDForum. Page generated in 0.59694 seconds
