Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] Updates and commits with concurrent users
[EMFStore] Updates and commits with concurrent users [message #1290931] |
Thu, 10 April 2014 11:11  |
My application needs a two-way sync capability in a multi-user (~10
users) environment sharing a common project, but I'm not sure the best
way to implement this. So far I naively implemented 'sync' as a
combination of EMFStore's update() and commit() operations, and I'm
struggling to avoid a race condition I've encountered during testing.
Since update() and commit() are separate operations, there is room for
another client (Client 2) to commit() in between Client 1's update() and
commit() operations. update() and commit() are separate but sometimes
dependent on one another and commits to the server can only be applied
once the client and server have a common version of the model -- which
may require an update from the server. Depending on the ordering of
these interweaved update() and commit() calls to the server from
concurrent clients, I've found that exceptions can be thrown that are
hard to recover from as there is no limit to the number times the
exceptions could recur.
Here's the scenario I've encountered using EMFStore's example merge
application to demonstrate how these "race conditions" occur. Since any
of the users can execute a commit() at any point, I've inserted a method
call at various points to simulate the effects of other clients
committing to the shared project
changeAndCommit(ESLocalProject demoProject)
to commit changes to the shared project on the server in between the
update, commit and commit retry for the demoProjectCopy.
Is there a coding pattern or example code I should adopt to implement a
two-way sync capability? Is there any locking feature in EMFStore that I
could use to eliminate the potential for the interweaving of update()
and commit() calls to the server from concurrent clients? Or perhaps
some other way to simulate an atomic sync function?
Here's the modified merge example code demonstrating the race condition:
package org.eclipse.emf.emfstore.example.merging;
import java.io.File;
import java.io.IOException;
import java.util.List;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.emf.emfstore.bowling.BowlingFactory;
import org.eclipse.emf.emfstore.bowling.League;
import org.eclipse.emf.emfstore.bowling.Player;
import org.eclipse.emf.emfstore.client.ESLocalProject;
import org.eclipse.emf.emfstore.client.ESServer;
import org.eclipse.emf.emfstore.client.ESWorkspace;
import org.eclipse.emf.emfstore.client.ESWorkspaceProvider;
import org.eclipse.emf.emfstore.client.callbacks.ESUpdateCallback;
import
org.eclipse.emf.emfstore.client.exceptions.ESServerStartFailedException;
import org.eclipse.emf.emfstore.common.ESSystemOutProgressMonitor;
import
org.eclipse.emf.emfstore.common.model.ESModelElementIdToEObjectMapping;
import org.eclipse.emf.emfstore.internal.client.model.Configuration;
import
org.eclipse.emf.emfstore.internal.client.model.exceptions.ChangeConflictException;
import org.eclipse.emf.emfstore.internal.common.model.util.FileUtil;
import org.eclipse.emf.emfstore.internal.server.ServerConfiguration;
import org.eclipse.emf.emfstore.server.ESConflict;
import org.eclipse.emf.emfstore.server.ESConflictSet;
import org.eclipse.emf.emfstore.server.exceptions.ESException;
import org.eclipse.emf.emfstore.server.exceptions.ESUpdateRequiredException;
import org.eclipse.emf.emfstore.server.model.ESChangePackage;
import org.eclipse.emf.emfstore.server.model.versionspec.ESVersionSpec;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
* An application that runs the demo.<br>
* Run a client that shows the merging feature of the EMFstore
* Please note: this is the programmatic way of merging
* EMFStore also provides a default UI for merging
* If there is a problem with the connection to the server
* e.g. a network, a specific ESException will be thrown
public class RaceConditionTestApplication implements IApplication {
* {@inheritDoc}
public Object start(IApplicationContext context) {
try {
cleanEmfstoreFolders();
// Create a client representation for a local server and start a
local server.
ESServer localServer = ESServer.FACTORY.createAndStartLocalServer();
* Reuse the client from the hello world example. It will clean up
all local and remote projects and create
* one project with some content on the server and two checked-out
copies of the project on the client.
org.eclipse.emf.emfstore.example.helloworld.Application.runClient(localServer);
// We run our own client code to demonstrate merging now.
} catch (ESServerStartFailedException e) {
System.out.println("Server start failed!");
e.printStackTrace();
} catch (ESException e) {
* e.g. a network, a specific EMFStoreException will be thrown
System.out.println("Connection to Server failed!");
return IApplication.EXIT_OK;
@SuppressWarnings("restriction")
private static void cleanEmfstoreFolders() {
try {
String clientWorkspaceDirectoryString =
Configuration.getFileInfo().getWorkspaceDirectory();
File clientWorkspaceDirectory = new File(clientWorkspaceDirectoryString);
System.out.println("Deleting client workspace directory " +
clientWorkspaceDirectory.getAbsolutePath());
FileUtil.deleteDirectory(clientWorkspaceDirectory, true);
String serverWorkspaceDirectoryString =
ServerConfiguration.getLocationProvider().getWorkspaceDirectory();
File serverWorkspaceDirectory = new File(serverWorkspaceDirectoryString);
System.out.println("Deleting server workspace directory " +
serverWorkspaceDirectory.getAbsolutePath());
FileUtil.deleteDirectory(serverWorkspaceDirectory, true);
} catch (IOException e) {
throw new RuntimeException(e);
public static void runClient(ESServer server) throws ESException {
System.out.println("Client starting...");
ESWorkspace workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
final ESLocalProject demoProject = workspace.getLocalProjects().get(0);
League league = (League) demoProject.getModelElements().get(0);
final ESLocalProject demoProjectCopy =
workspace.getLocalProjects().get(1);
League leagueCopy = (League) demoProjectCopy.getModelElements().get(0);
// Change the name of the league in project 1,add a new player and
commit the change
league.setName("Euro-League");
Player newPlayer = BowlingFactory.eINSTANCE.createPlayer();
newPlayer.setName("Eugene");
league.getPlayers().add(newPlayer);
demoProject.commit(new ESSystemOutProgressMonitor());
* Changing the name again value without calling update() on the copy
first will cause a conflict on commit.
* We also add one change which is non-conflicting, setting the name
of the first player.
leagueCopy.setName("EU-League");
leagueCopy.getPlayers().get(0).setName("Johannes");
try {
demoProjectCopy.commit(new ESSystemOutProgressMonitor());
} catch (ESUpdateRequiredException e) {
// The commit failed since the other demoProject was committed first
and therefore demoProjectCopy needs an
// update
System.out.println("\nCommit of demoProjectCopy failed.");
// We run update in demoProjectCopy with an UpdateCallback to handle
conflicts
System.out.println("\nUpdate of demoProjectCopy with conflict
resolver...");
demoProjectCopy.update(ESVersionSpec.FACTORY.createHEAD(), new
ESUpdateCallback() {
boolean changeMade = false;
public void noChangesOnServer() {
* do nothing if there are no changes on the server (in this
example we know
* there are changes anyway)
public boolean inspectChanges(ESLocalProject project,
List<ESChangePackage> changes,
ESModelElementIdToEObjectMapping idToEObjectMapping) {
* If another client commits to the project during
inspectChanges(), the UpdateController throws
* "ChangeConflictException: Conflict detected on update"
if (false) {
changeAndCommit(demoProject);
// allow update to proceed, here we could also add some UI
return true;
public boolean conflictOccurred(ESConflictSet changeConflictSet,
IProgressMonitor monitor) {
if (!changeMade && false) {
changeMade = true;
* One or more conflicts have occured, they are delivered in a
change conflict set
* We know there is only one conflict so we grab it
ESConflict conflict =
changeConflictSet.getConflicts().iterator().next();
* We resolve the conflict by accepting all of the conflicting
local operations and rejecting all of
* the remote operations. This means that we revert the league name
change of demoProject and accept
* the league name change of demoProjectCopy. The player name
change in demoProject is accepted also
* since it was not conflicting with any other change.
conflict.resolveConflict(conflict.getLocalOperations(),
conflict.getRemoteOperations());
* Finally we claim to have resolved all conflicts so update will
try to proceed.
return true;
}, new ESSystemOutProgressMonitor());
* Commits from other clients at this point results in another
* "ESUpdateRequiredException: BaseVersion outdated, please update
before commit." exception being thrown.
// commit merge result in project 2
System.out.println("\nCommit of merge result of demoProjectCopy");
// After having merged the two projects update local project 1
System.out.println("\nUpdate of demoProject");
demoProject.update(new NullProgressMonitor());
// Finally we print the league and player names of both projects
System.out.println("\nLeague name in demoProject is now: " +
league.getName());
System.out.println("\nLeague name in demoProjectCopy is now: " +
leagueCopy.getName());
System.out.println("\nPlayer name in demoProject is now: " +
league.getPlayers().get(0).getName());
System.out.println("\nPlayer name in demoProjectCopy is now: " +
leagueCopy.getPlayers().get(0).getName());
private static void changeAndCommit(ESLocalProject demoProject) {
league.setName("Another name");
newPlayer.setName("Bill");
try {
public void stop() {
// do nothing
Re: [EMFStore] Updates and commits with concurrent users [message #1291816 is a reply to message #1290931] |
Fri, 11 April 2014 04:36   |
Hi Scott,
if I understand you correctly the "race conditions" are conceptional
race conditions not real technical race conditions. They result from the
conceptional problem that clients can commit at any time but only if
they have updated to the current head version they succeed with their
commit. This is since otherwise a merge is required because of
concurrent changes. If any client commits in between the other clients
update and commit attempt, the other client is forced to update again.
The exceptions that you encounter are probably
ESUpdateRequiredException, right?
Maximilian
Am 10.04.2014 17:11, schrieb scott@xxxxxxxx:
> import
> import
> import
> import
> * {@inheritDoc}
> try {
> start a local server.
> clean up all local and remote projects and create
> checked-out copies of the project on the client.
> try {
> and commit the change
> copy first will cause a conflict on commit.
> name of the first player.
> try {
> committed first and therefore demoProjectCopy needs an
> // update
> to handle conflicts
> conflict resolver...");
> new ESUpdateCallback() {
> (in this example we know
> update"
> if (false) {
> some UI
> return true;
> changeConflictSet, IProgressMonitor monitor) {
> update"
> changeMade = true;
> delivered in a change conflict set
> conflicting local operations and rejecting all of
> the league name change of demoProject and accept
> player name change in demoProject is accepted also
> so update will try to proceed.
> return true;
> update before commit." exception being thrown.
> demoProjectCopy");
> projects
> + league.getName());
> now: " + leagueCopy.getName());
> " + leagueCopy.getPlayers().get(0).getName());
> try {
> // do nothing
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Updates and commits with concurrent users [message #1294971 is a reply to message #1291816] |
Sun, 13 April 2014 19:56   |
Yes, your explanation sounds right and I get both
ESUpdateRequiredException and ChangeConflictException depending where
the other client update occurs.
For example in the program I attached, if another client commits to the
project during inspectChanges(), the UpdateController throws
update".
Know any solutions to this problem?
$cott
On 4/11/2014 4:36 AM, Maximilian Koegel wrote:
> Hi Scott,
> Cheers,
> Maximilian
>> import
>> import
>> import
>> import
>> * {@inheritDoc}
>> try {
>> try {
>> try {
>> // update
>> to handle conflicts
>> update"
>> if (false) {
>> some UI
>> return true;
>> update"
>> changeMade = true;
>> return true;
>> demoProjectCopy");
>> projects
>> try {
>> // do nothing
Re: [EMFStore] Updates and commits with concurrent users [message #1295559 is a reply to message #1294971] |
Mon, 14 April 2014 07:24   |
ESUpdateRequiredException means your client´s project is outdated and
needs an Update. You could keep updating but there is no guarantee it
will ever succeed to commit since other clients could keep pushing in
commits. To block other clients from making commits would require
additional API for locking, which is currently not implemented.
ChangeConflictException means your client´s project has conflicting
local changes with an update incoming from the server, which need to be
resolved by merging. They could be auto-merged (conflictOccurred method)
by just dropping one of the changes, if this is something that is
acceptable in your application.
Maximilian
Am 14.04.2014 01:56, schrieb scott@xxxxxxxx:
> update".
> $cott
>> Hi Scott,
>> Cheers,
>> Maximilian
>>> import
>>> import
>>> import
>>> import
>>> * {@inheritDoc}
>>> try {
>>> thrown
>>> try {
>>> the
>>> try {
>>> // update
>>> to handle conflicts
>>> update"
>>> if (false) {
>>> some UI
>>> return true;
>>> update"
>>> changeMade = true;
>>> change.
>>> return true;
>>> another
>>> demoProjectCopy");
>>> project 1
>>> projects
>>> now:
>>> try {
>>> // do nothing
Maximilian Kögel
Re: [EMFStore] Updates and commits with concurrent users [message #1295655 is a reply to message #1295559] |
Mon, 14 April 2014 09:05   |
OK, thanks for the quick response.
Without a locking mechanism or a native two-way sync() function, it
sounds like I'll need to repeatedly retry the update() and commit()
until it succeeds or exceeds a retry limit. Hopefully that will work for
the limited number of concurrent users I need to support.
Any plans to implement a native sync() or lock mechanism?
Scott
> Cheers,
> Maximilian
>> update".
>> $cott
>>> Hi Scott,
>>> Cheers,
>>> Maximilian
>>>> import
>>>> import
>>>> import
>>>> import
>>>> * {@inheritDoc}
>>>> try {
>>>> thrown
>>>> try {
>>>> the
>>>> try {
>>>> // update
>>>> to handle conflicts
>>>> update"
>>>> if (false) {
>>>> some UI
>>>> return true;
>>>> update"
>>>> changeMade = true;
>>>> change.
>>>> return true;
>>>> another
>>>> demoProjectCopy");
>>>> project 1
>>>> projects
>>>> now:
>>>> try {
>>>> // do nothing
Re: [EMFStore] Updates and commits with concurrent users [message #1296930 is a reply to message #1295655] |
Tue, 15 April 2014 05:51   |
Yes, that is correct. EMFStore is intended for offline usage, like git
or svn, so typically you will not have many competing commits at the
same time. The problem with an atomic update and commit is that often
merging is done interactively so a lock would hold of all other clients.
I would accept a time-baed lock for a project a additional API though in
case you would propose a patch. We have no plans to implement something
like that ourself at his time.
Maximilian
Am 14.04.2014 15:05, schrieb scott@xxxxxxxx:
> Scott
>> Cheers,
>> Maximilian
>>> update".
>>> $cott
>>>> Hi Scott,
>>>> the
>>>> Cheers,
>>>> Maximilian
>>>>> update() and
>>>>> any
>>>>> method
>>>>> implement a
>>>>> that I
>>>>> condition:
>>>>> import
>>>>> import
>>>>> import
>>>>> import
>>>>> import
>>>>> * {@inheritDoc}
>>>>> try {
>>>>> will
>>>>> now.
>>>>> server
>>>>> thrown
>>>>> try {
>>>>> directory " +
>>>>> true);
>>>>> directory " +
>>>>> true);
>>>>> ESException {
>>>>> player
>>>>> the
>>>>> setting the
>>>>> try {
>>>>> // update
>>>>> failed.");
>>>>> UpdateCallback
>>>>> to handle conflicts
>>>>> server
>>>>> project,
>>>>> during
>>>>> detected on
>>>>> update"
>>>>> if (false) {
>>>>> also add
>>>>> some UI
>>>>> return true;
>>>>> during
>>>>> detected on
>>>>> update"
>>>>> changeMade = true;
>>>>> grab it
>>>>> of the
>>>>> revert
>>>>> The
>>>>> change.
>>>>> conflicts
>>>>> return true;
>>>>> another
>>>>> please
>>>>> demoProjectCopy");
>>>>> project 1
>>>>> projects
>>>>> now: "
>>>>> now:
>>>>> demoProject) {
>>>>> try {
>>>>> // do nothing
Maximilian Kögel
Re: [EMFStore] Updates and commits with concurrent users [message #1328152 is a reply to message #1296930] |
Fri, 02 May 2014 10:43   |
My testing shows that slow connections significantly increase the
likelihood of competing commits, so my application will need this lock.
I'll learn more about the EMFStore server internals and how best to
implement this locking capability.
Can you say a little more about how you envision the time-based lock to
work? Is the timeout you suggest for acquiring the lock or for
restricting the maximum time the lock can be held (an auto-unlock
feature) -- or both?
I'm thinking of four new methods in VersionSubInterfaceImpl something
like this:
acquireLock(String sessionId, String projectId, int acquireTimeout)
releaseLock(String sessionId, String projectId)
acquireLockAndGetChanges(...)
createVersionAndReleaseLock(...)
Any suggestions are welcome.
$cott
> Cheers,
> Maximilian
>> Thanks,
>> Scott
>>> Cheers,
>>> Maximilian
>>>> update".
>>>> $cott
>>>>> Hi Scott,
>>>>> the
>>>>> Cheers,
>>>>> Maximilian
>>>>>> update() and
>>>>>> any
>>>>>> method
>>>>>> implement a
>>>>>> that I
>>>>>> condition:
>>>>>> import
>>>>>> import
>>>>>> import
>>>>>> import
>>>>>> import
>>>>>> * {@inheritDoc}
>>>>>> try {
>>>>>> will
>>>>>> now.
>>>>>> server
>>>>>> thrown
>>>>>> try {
>>>>>> directory " +
>>>>>> true);
>>>>>> directory " +
>>>>>> true);
>>>>>> ESException {
>>>>>> player
>>>>>> the
>>>>>> setting the
>>>>>> try {
>>>>>> // update
>>>>>> failed.");
>>>>>> UpdateCallback
>>>>>> to handle conflicts
>>>>>> server
>>>>>> project,
>>>>>> during
>>>>>> detected on
>>>>>> update"
>>>>>> if (false) {
>>>>>> also add
>>>>>> some UI
>>>>>> return true;
>>>>>> during
>>>>>> detected on
>>>>>> update"
>>>>>> changeMade = true;
>>>>>> grab it
>>>>>> of the
>>>>>> revert
>>>>>> The
>>>>>> change.
>>>>>> conflicts
>>>>>> return true;
>>>>>> another
>>>>>> please
>>>>>> demoProjectCopy");
>>>>>> project 1
>>>>>> projects
>>>>>> now: "
>>>>>> now:
>>>>>> demoProject) {
>>>>>> try {
>>>>>> // do nothing
Re: [EMFStore] Updates and commits with concurrent users [message #1336051 is a reply to message #1328152] |
Tue, 06 May 2014 03:59   |
Hi Scott,
what you propose is what I expected, although I would only offer two
methods:
To my understanding the other methods could be offered on the client
side as convenience but are not required on server side.
What do you think?
Maximilian
P.S.: We also offer professional services in case you would like to
delegate the implementation to us ;).
Am 02.05.2014 16:43, schrieb scott@xxxxxxxx:
> like this:
> $cott
>> Cheers,
>> Maximilian
>>> Thanks,
>>> Scott
>>>> method)
>>>> Cheers,
>>>> Maximilian
>>>>> the
>>>>> update".
>>>>> $cott
>>>>>> Hi Scott,
>>>>>> the
>>>>>> clients
>>>>>> again.
>>>>>> Cheers,
>>>>>> Maximilian
>>>>>>> best
>>>>>>> testing.
>>>>>>> room for
>>>>>>> update() and
>>>>>>> sometimes
>>>>>>> applied
>>>>>>> which
>>>>>>> are
>>>>>>> any
>>>>>>> method
>>>>>>> implement a
>>>>>>> that I
>>>>>>> update()
>>>>>>> condition:
>>>>>>> import
>>>>>>> import
>>>>>>> import
>>>>>>> import
>>>>>>> import
>>>>>>> * {@inheritDoc}
>>>>>>> try {
>>>>>>> server and
>>>>>>> will
>>>>>>> two
>>>>>>> now.
>>>>>>> server
>>>>>>> will be
>>>>>>> thrown
>>>>>>> try {
>>>>>>> directory " +
>>>>>>> true);
>>>>>>> directory " +
>>>>>>> true);
>>>>>>> ESException {
>>>>>>> player
>>>>>>> Player newPlayer =
>>>>>>> update() on
>>>>>>> the
>>>>>>> setting the
>>>>>>> try {
>>>>>>> // update
>>>>>>> failed.");
>>>>>>> UpdateCallback
>>>>>>> to handle conflicts
>>>>>>> server
>>>>>>> project,
>>>>>>> during
>>>>>>> detected on
>>>>>>> update"
>>>>>>> if (false) {
>>>>>>> also add
>>>>>>> some UI
>>>>>>> return true;
>>>>>>> during
>>>>>>> detected on
>>>>>>> update"
>>>>>>> changeMade = true;
>>>>>>> they are
>>>>>>> grab it
>>>>>>> of the
>>>>>>> revert
>>>>>>> The
>>>>>>> other
>>>>>>> change.
>>>>>>> conflicts
>>>>>>> return true;
>>>>>>> results in
>>>>>>> another
>>>>>>> please
>>>>>>> demoProjectCopy");
>>>>>>> project 1
>>>>>>> both
>>>>>>> projects
>>>>>>> now: "
>>>>>>> demoProjectCopy is
>>>>>>> is now:
>>>>>>> demoProjectCopy is
>>>>>>> now:
>>>>>>> demoProject) {
>>>>>>> Player newPlayer =
>>>>>>> try {
>>>>>>> // do nothing
Maximilian Kögel
Re: [EMFStore] Updates and commits with concurrent users [message #1337168 is a reply to message #1336051] |
Tue, 06 May 2014 15:00   |
The primary advantage of combining the locking and versioning methods
into one server side XML-RPC service is performance. Doing so reduces
the number of round trips to the server and minimizes the time the lock
is held. Since the current EMFStore implementation is based on the
XML-RPC WebServer, a new TCP/IP connection is built and torn down for
every request and this is somewhat expensive over a cell network.
Since I really don't know the performance impact of implementing the
composed lock/update & commit/unlock services vs. making individual
calls for each one, it's hard to make a case one way or another.
Let's let the data tell us what to do. Once the locking functions are
built, I can performance test client-side and service-side
implementations of the composed services and decide whether adding the
additional methods to the core API is justified.
Sound OK?
Scott
On 5/6/2014 3:59 AM, Maximilian Koegel wrote:
> Hi Scott,
> methods:
> What do you think?
> Cheers,
> Maximilian
>> like this:
>> $cott
>>> Cheers,
>>> Maximilian
>>>> Thanks,
>>>> Scott
>>>>> method)
>>>>> Cheers,
>>>>> Maximilian
>>>>>> the
>>>>>> update".
>>>>>> $cott
>>>>>>> Hi Scott,
>>>>>>> the
>>>>>>> clients
>>>>>>> again.
>>>>>>> Cheers,
>>>>>>> Maximilian
>>>>>>>> best
>>>>>>>> testing.
>>>>>>>> room for
>>>>>>>> update() and
>>>>>>>> sometimes
>>>>>>>> applied
>>>>>>>> which
>>>>>>>> are
>>>>>>>> any
>>>>>>>> method
>>>>>>>> implement a
>>>>>>>> that I
>>>>>>>> update()
>>>>>>>> condition:
>>>>>>>> import
>>>>>>>> import
>>>>>>>> import
>>>>>>>> import
>>>>>>>> import
>>>>>>>> * {@inheritDoc}
>>>>>>>> try {
>>>>>>>> server and
>>>>>>>> will
>>>>>>>> two
>>>>>>>> now.
>>>>>>>> server
>>>>>>>> will be
>>>>>>>> thrown
>>>>>>>> try {
>>>>>>>> directory " +
>>>>>>>> true);
>>>>>>>> directory " +
>>>>>>>> true);
>>>>>>>> ESException {
>>>>>>>> player
>>>>>>>> Player newPlayer =
>>>>>>>> update() on
>>>>>>>> the
>>>>>>>> setting the
>>>>>>>> try {
>>>>>>>> // update
>>>>>>>> failed.");
>>>>>>>> UpdateCallback
>>>>>>>> to handle conflicts
>>>>>>>> server
>>>>>>>> project,
>>>>>>>> during
>>>>>>>> detected on
>>>>>>>> update"
>>>>>>>> if (false) {
>>>>>>>> also add
>>>>>>>> some UI
>>>>>>>> return true;
>>>>>>>> during
>>>>>>>> detected on
>>>>>>>> update"
>>>>>>>> changeMade = true;
>>>>>>>> they are
>>>>>>>> grab it
>>>>>>>> of the
>>>>>>>> revert
>>>>>>>> The
>>>>>>>> other
>>>>>>>> change.
>>>>>>>> conflicts
>>>>>>>> return true;
>>>>>>>> results in
>>>>>>>> another
>>>>>>>> please
>>>>>>>> demoProjectCopy");
>>>>>>>> project 1
>>>>>>>> both
>>>>>>>> projects
>>>>>>>> now: "
>>>>>>>> demoProjectCopy is
>>>>>>>> is now:
>>>>>>>> demoProjectCopy is
>>>>>>>> now:
>>>>>>>> demoProject) {
>>>>>>>> Player newPlayer =
>>>>>>>> try {
>>>>>>>> // do nothing
Re: [EMFStore] Updates and commits with concurrent users [message #1338533 is a reply to message #1337168] |
Wed, 07 May 2014 04:59   |
OK, sounds like a plan ;).
Maximilian
Am 06.05.2014 21:00, schrieb Scott Dybiec:
> Sound OK?
> Scott
>> Hi Scott,
>> methods:
>> What do you think?
>> Cheers,
>> Maximilian
>>> like this:
>>> $cott
>>>> clients.
>>>> though in
>>>> Cheers,
>>>> Maximilian
>>>>> work for
>>>>> Thanks,
>>>>> Scott
>>>>>> to be
>>>>>> method)
>>>>>> Cheers,
>>>>>> Maximilian
>>>>>>> where
>>>>>>> the
>>>>>>> update".
>>>>>>> $cott
>>>>>>>> Hi Scott,
>>>>>>>> conceptional
>>>>>>>> from
>>>>>>>> the
>>>>>>>> only if
>>>>>>>> their
>>>>>>>> clients
>>>>>>>> again.
>>>>>>>> Cheers,
>>>>>>>> Maximilian
>>>>>>>>> (~10
>>>>>>>>> best
>>>>>>>>> I'm
>>>>>>>>> testing.
>>>>>>>>> room for
>>>>>>>>> update() and
>>>>>>>>> sometimes
>>>>>>>>> applied
>>>>>>>>> which
>>>>>>>>> ordering of
>>>>>>>>> are
>>>>>>>>> merge
>>>>>>>>> Since
>>>>>>>>> any
>>>>>>>>> method
>>>>>>>>> between the
>>>>>>>>> implement a
>>>>>>>>> that I
>>>>>>>>> update()
>>>>>>>>> perhaps
>>>>>>>>> condition:
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> import
>>>>>>>>> IApplication {
>>>>>>>>> * {@inheritDoc}
>>>>>>>>> try {
>>>>>>>>> server and
>>>>>>>>> example. It
>>>>>>>>> will
>>>>>>>>> two
>>>>>>>>> merging
>>>>>>>>> now.
>>>>>>>>> the
>>>>>>>>> server
>>>>>>>>> will be
>>>>>>>>> thrown
>>>>>>>>> failed!");
>>>>>>>>> try {
>>>>>>>>> directory " +
>>>>>>>>> true);
>>>>>>>>> directory " +
>>>>>>>>> true);
>>>>>>>>> ESException {
>>>>>>>>> new
>>>>>>>>> player
>>>>>>>>> Player newPlayer =
>>>>>>>>> update() on
>>>>>>>>> the
>>>>>>>>> setting the
>>>>>>>>> try {
>>>>>>>>> demoProject was
>>>>>>>>> // update
>>>>>>>>> failed.");
>>>>>>>>> UpdateCallback
>>>>>>>>> to handle conflicts
>>>>>>>>> with
>>>>>>>>> on the
>>>>>>>>> server
>>>>>>>>> project,
>>>>>>>>> project
>>>>>>>>> during
>>>>>>>>> detected on
>>>>>>>>> update"
>>>>>>>>> if (false) {
>>>>>>>>> also add
>>>>>>>>> some UI
>>>>>>>>> return true;
>>>>>>>>> project
>>>>>>>>> during
>>>>>>>>> detected on
>>>>>>>>> update"
>>>>>>>>> changeMade = true;
>>>>>>>>> they are
>>>>>>>>> so we
>>>>>>>>> grab it
>>>>>>>>> all
>>>>>>>>> of the
>>>>>>>>> that we
>>>>>>>>> revert
>>>>>>>>> demoProjectCopy.
>>>>>>>>> The
>>>>>>>>> other
>>>>>>>>> change.
>>>>>>>>> conflicts
>>>>>>>>> return true;
>>>>>>>>> results in
>>>>>>>>> another
>>>>>>>>> outdated,
>>>>>>>>> please
>>>>>>>>> demoProjectCopy");
>>>>>>>>> local
>>>>>>>>> project 1
>>>>>>>>> both
>>>>>>>>> projects
>>>>>>>>> demoProject is
>>>>>>>>> now: "
>>>>>>>>> demoProjectCopy is
>>>>>>>>> is now:
>>>>>>>>> demoProjectCopy is
>>>>>>>>> now:
>>>>>>>>> demoProject) {
>>>>>>>>> Player newPlayer =
>>>>>>>>> try {
>>>>>>>>> // do nothing
Maximilian Kögel
Current Time: Sat Jul 26 22:25:22 EDT 2025
Powered by FUDForum. Page generated in 0.12758 seconds
