Home » Eclipse Projects » Eclipse 4 » PartDescriptor in Fragment
PartDescriptor in Fragment [message #1271199] Fri, 14 March 2014 09:36 Go to next message
Does anyone know if it is possible to use a PartDescriptor for an MPart in a ModelFragment?
When I do so and then trace the code in the ModelServiceImpl.class the only PartDescriptors I find there are the ones defined in the main Application - no descriptors from the fragment are found.
There was a post on this in 2012 http://www.eclipse.org/forums/index.php/t/366973/ and a bugzilla bugs.eclipse.org/bugs/show_bug.cgi?id=384514. The bugzilla tracker defines the bug as fixed in Nov 2013 - with a patch to org.eclipse.e4.tools.emf.ui...SharedElementsDialog.java but I am not using SharedElementsDialog.
Any ideas?
Cheers
Don
Re: PartDescriptor in Fragment [message #1280168 is a reply to message #1271199] Sat, 29 March 2014 18:50 Go to previous messageGo to next message
So you can not add add it from the application model editor or you add it and the model service doesn't find it?
Re: PartDescriptor in Fragment [message #1281111 is a reply to message #1271199] Mon, 31 March 2014 07:24 Go to previous messageGo to next message
The problem with model fragment is that you need to know the ID of your application. If you add your part descriptor in your application model and then you extract it into a fragment you will see the application ID in the model fragment. If your fragment is dedicated to a specific application it will be ok, and by extracting the fragment it should work.
May be it would be easier to use a Processor to describe it. In this case you don't need to know the application ID. Instead of choosing 'fragment' in the extension, choose 'Processor' and bind a POJO class containing an '@Execute' method that will receive the MApplication, modelService and all stuff needed :
You can then add the part descriptor using a code like this :
@Execute
public void fillMyModel(MApplication application, EModelService modelService)
MPartDescriptor descriptor = modelService.createModelElement(MPartDescriptor.class);
descriptor.setElementId(MyPart.class.getCanonicalName());
descriptor.setLabel(partLabel);
descriptor.setCloseable(true);
String bundle = FrameworkUtil.getBundle(myPart.class).getSymbolicName();
descriptor.setContributionURI("bundleclass://" + bundle + "/" + myPart.class.getCanonicalName());
String contributorURI = "platform:/plugin/" + FrameworkUtil.getBundle(myPart.class).getSymbolicName();
descriptor.setContributorURI(contributorURI);
descriptor.setIconURI(iconPath.toString());
application.getDescriptors().add(descriptor);
Re: PartDescriptor in Fragment [message #1282050 is a reply to message #1281111] Tue, 01 April 2014 16:05 Go to previous messageGo to next message
This is most likely awaiting the XPath implementation for fragment processing which would allow you to explicitly define the container without having to resort to using hte id.
Re: PartDescriptor in Fragment [message #1290870 is a reply to message #1282050] Thu, 10 April 2014 10:09 Go to previous messageGo to next message
Thanks everyone,
I initially got this working by leaving all the model fragments (commands, handlers, menus) in the plugin, then registering PartDescriptors in the main Application.e4xmi that refernce the plugin view bundleclasses - not elegent but works.
After reading your posts, I tried extracting the part descriptor as a fragment -both into the main app and into the plugin. Neither worked.
I then tried creating a processor inside the plug-in. This method appears promising - I managed to get it add items to the menu in the main application, though there now seems to be an issue injecting a Composite into a POJO on @PostConstruct in views in the plugin.
Don
Re: PartDescriptor in Fragment [message #1433127 is a reply to message #1290870] Sun, 28 September 2014 04:14 Go to previous message
Don Smyth wrote on Thu, 10 April 2014 10:09
Don
To solve this problem add as required plug-in javax.annotation, as result method marked as @PostConstruct will works.
Previous Topic:re-creating a closed Part
Next Topic:Fragments of Fragments
Current Time: Fri Jul 25 10:30:35 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
