Home » Modeling » M2T (model-to-text transformation) » How to import ecore2ecore in template?
How to import ecore2ecore in template? [message #1286431] Sun, 06 April 2014 14:30 Go to next message
I have a generate template based on a ecore2ecore file as in the attached.
I would like to be able to parse the Ecore2EcoreMappingRoot, and yet in the for loop I get an error "Mapping: Invalid Type".
Is there any sample template for Ecore2Ecore files that I can use?
Otherwise how could I parse an ecore2core file?
For reference, I attach my sample ecore2ecore file and my template file.
Re: How to import ecore2ecore in template? [message #1290008 is a reply to message #1286431] Wed, 09 April 2014 17:05 Go to previous messageGo to next message
To complement my previous message, here's how the files look like:
The .ecore2ecore file is attached as nav-quantiv.ecore2ecore
The .mtl template file is as
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/emf/2004/Ecore2Ecore')]
[template public generateElement(anEcore2EcoreMappingRoot : Ecore2EcoreMappingRoot)]
[comment @main/]
[file ('test', false, 'UTF-8')]
[for (a: Mapping | anEcore2EcoreMappingRoot.nested)]
[/for]
[/file]
[/template]
When I hover the ".nested" part of the above in the .mtl file I get:
"[EReference] nested: Mapping[0..*]"
And yet I get the "Mapping" underlined with a red bar (error) and the error being reported in the template for the "Mapping" is:
"Invalid Type: Mapping"
Please note that the Mapping we're talking about here is the org.eclipse.emf.mapping.Mapping
Is Ecore2Ecore really supported by Acceleo?
Would anyone happen to have an example of a template parsing the .ecore2ecore file?
Re: How to import ecore2ecore in template? [message #1290468 is a reply to message #1290008] Thu, 10 April 2014 02:30 Go to previous messageGo to next message
http://www.eclipse.org/emf/2004/Ecore2Ecore 'delegates' to
http://www.eclipse.org/emf/2002/Mapping. If you want to use names from
an unimported model you must either qualify them as mapping::Mapping or.
Better to just add the extra nsURI to your generate 'imports'.
Ed Willink
Re: How to import ecore2ecore in template? [message #1290562 is a reply to message #1290468] Thu, 10 April 2014 04:15 Go to previous messageGo to next message
Using the following works well and thank you very much for your response:
[for (m: mapping::Mapping | anEcore2EcoreMappingRoot.nested)]
[/for]
Regarding the import though, when I use the following:
[import org::eclipse::emf::mapping]
I get a compilation error:
Module org::eclipse::emf::mapping not found.
Any ideas why this might happen?
Again thank you very much for getting me going; your help is greatly appreciated.
Re: How to import ecore2ecore in template? [message #1290615 is a reply to message #1290562] Thu, 10 April 2014 05:15 Go to previous message
[import .../] is for MTL imports
[module generate('http://www.eclipse.org/emf/2004/Ecore2Ecore', ...)]
is for metamodel references.
Ed Willink
> [/for]
> appreciated.
Previous Topic:Access metamodel elemnets from model
Next Topic:[Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui
Current Time: Mon Jul 21 09:18:53 EDT 2025
Powered by FUDForum. Page generated in 0.05697 seconds
