Home » Archived » Test and Performance Tools Platform (TPTP) » Java - Attach Process, never an option
Java - Attach Process, never an option [message #129016] Wed, 23 April 2008 13:51 Go to next message
Originally posted by: todd.trimmer.gmail.com
In the Profile Wizard, I never get Java - Attach Process as even showing
up for selection. This is what I downloaded and installed fresh:
Eclipse 3.3.2
TPTP "All in One" 4.4
WTP 2.0.2
BIRT 2.2.2
GEF 3.3.2
DTP 1.5.3
AJDT 1.5.1
Agent Controller WINDOWS-IA32
I installed the Agent Controller, put it on the PATH, ran SetupConfig,
bounced it as a Windows Service.
Despite all of this, Java - Attach Process is not available. Just about
every other option in that tree I've seen in other screenshots is
available, so why not this one?
Re: Java - Attach Process, never an option [message #129029 is a reply to message #129016] Thu, 24 April 2008 04:00 Go to previous messageGo to next message
"Attach to agent" option assumes that you have launched profiling manualy
in enabled or controlled mode. Using this option you can attach/detach to
this process.
Re: Java - Attach Process, never an option [message #129042 is a reply to message #129029] Thu, 24 April 2008 12:02 Go to previous message
OK, so I'm assuming the wording on the UI has changed from one release to
the next. Since I was looking at a screenshot dated just last month, I
thought I was viewing something rather up-to-date.
I have used the Attach to Agent option with some success and will continue
playing with it.
Thanks!
Previous Topic:Recording web services communication
Next Topic:No local direct connection on IAC
Current Time: Fri Jul 25 22:47:16 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
