Home » Language IDEs » C / C++ IDE (CDT) » OS X, CDT debug problem: Exception processing debug async queue
OS X, CDT debug problem: Exception processing debug async queue [message #128924] |
Fri, 26 November 2004 09:38  |
I am terribly new to this, so forgive me if the following has some obvious solution. =)
I get this from my error log every time I attempt to run a program in debug mode:
Error Nov 26, 2004 08:55:10.292 Exception processing debug async queue
at org.eclipse.cdt.debug.internal.core.model.CStackFrame.getAdd ress(CStackFrame.java:554)
at org.eclipse.cdt.debug.internal.core.model.Disassembly.create Block(Disassembly.java:64)
at org.eclipse.cdt.debug.internal.core.model.Disassembly.getDis assemblyBlock(Disassembly.java:53)
at org.eclipse.cdt.debug.internal.ui.views.disassembly.Disassem blyEditorInput.create(DisassemblyEditorInput.java:192)
at org.eclipse.cdt.debug.internal.ui.views.disassembly.Disassem blyView$4.run(DisassemblyView.java:544)
at org.eclipse.debug.core.DebugPlugin$AsynchJob.run(DebugPlugin .java:876)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
Session Data:
eclipse.buildId=M200409161125java.version=1.4.2_05
java.vendor=Apple Computer, Inc.BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Command-line arguments: -keyring /Users/inca/.eclipse_keyring -showlocation
What does it mean and what can I do to fix it?
Joe
Re: OS X, CDT debug problem: Exception processing debug async queue [message #129008 is a reply to message #128986] |
Fri, 26 November 2004 15:15   |
CDT 2.1.0 RC3 from
http://download.eclipse.org/tools/cdt/builds/2.1.0/RC3
The async problem occurs only when I look for the "disassembly" when stepping through the debug mode.
I have a new error now:
An internal error occurred during: "Debug".
at org.eclipse.cdt.debug.internal.core.model.CValue.getPointerV alueString(CValue.java:367)
at org.eclipse.cdt.debug.internal.core.model.CValue.processUnde rlyingValue(CValue.java:216)
at org.eclipse.cdt.debug.internal.core.model.CValue.getValueStr ing(CValue.java:95)
at org.eclipse.cdt.debug.internal.ui.CDTDebugModelPresentation. getValueText(CDTDebugModelPresentation.java:568)
at org.eclipse.cdt.debug.internal.ui.CDTDebugModelPresentation. getVariableText(CDTDebugModelPresentation.java:545)
at org.eclipse.cdt.debug.internal.ui.CDTDebugModelPresentation. getBaseText(CDTDebugModelPresentation.java:323)
at org.eclipse.cdt.debug.internal.ui.CDTDebugModelPresentation. getText(CDTDebugModelPresentation.java:287)
at org.eclipse.debug.internal.ui.LazyModelPresentation.getText( LazyModelPresentation.java:101)
at org.eclipse.debug.internal.ui.DelegatingModelPresentation.ge tText(DelegatingModelPresentation.java:158)
at org.eclipse.debug.internal.ui.VariablesViewModelPresentation .getText(VariablesViewModelPresentation.java:25)
at org.eclipse.debug.internal.ui.views.DebugViewLabelDecorator$ LabelJob.run(DebugViewLabelDecorator.java:326)
In article <co7u9n$d7d$1@www.eclipse.org>,
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote:
> Which version of CDT are you using?
> "Joe Gorse" <gorse@mps.ohio-state.edu> wrote in message
> news:gorse-C256DB.09382726112004@eclipse.org...
> >solution. =)
> > debug mode:
> > java.lang.NullPointerException
> > at
> > at
> > at
> > at
> > at
> > Session Data:
> > WS=carbon, NL=en_US
> > Thanks,
> > Joe
Re: OS X, CDT debug problem: Exception processing debug async queue [message #131126 is a reply to message #129008] |
Thu, 09 December 2004 13:20   |
Originally posted by: gwatson.lanl.gov
I get the same error as soon as I start debugging a CDT project. I'm using
Platform 3.0.1 and the CDT plugin from CVS HEAD. Is there a bug ID for
this?
Greg
Joe Gorse wrote:
> CDT 2.1.0 RC3 from
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> >solution. =)
>> > debug mode:
>> > at
>> > at
>> > at
>> > at
>> > at
>> > Session Data:
ARCH=ppc,
>> > WS=carbon, NL=en_US
>> > Thanks,
>> > Joe
Re: OS X, CDT debug problem: Exception processing debug async queue [message #131329 is a reply to message #131126] |
Fri, 10 December 2004 16:37   |
This has now been fixed in 2.1.
Greg
> using Platform 3.0.1 and the CDT plugin from CVS HEAD. Is there a bug ID
> for this?
> Greg
> Joe Gorse wrote:
>> CDT 2.1.0 RC3 from
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> -showlocation
>>> obvious >solution. =)
>>> in > debug mode:
>>> > at >
>>> > at >
>>> > at >
>>> > at >
>>> > at >
>>> > at
>>> > Session Data:
> ARCH=ppc,
>>> > WS=carbon, NL=en_US
>>> > Command-line arguments: -keyring > /Users/inca/.eclipse_keyring
>>> -showlocation
>>> > Thanks,
>>> > Joe
Re: OS X, CDT debug problem: Exception processing debug async queue [message #133657 is a reply to message #131329] |
Wed, 05 January 2005 18:37  |
Greg,
Are you running on a Mac or PC?
Joe
In article <cpd4uu$iun$1@www.eclipse.org>,
> Greg
> > for this?
> > Greg
> > Joe Gorse wrote:
> >> CDT 2.1.0 RC3 from
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> -showlocation
> >>> in > debug mode:
> >>> > at >
> >>> > at >
> >>> > at >
> >>> > at >
> >>> > at >
> >>> > at
> >>> > Session Data:
> > ARCH=ppc,
> >>> > WS=carbon, NL=en_US
> >>> -showlocation
> >>> > Thanks,
> >>> > Joe
Current Time: Fri Sep 19 04:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.04617 seconds
