Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #128818 is a reply to message #128805] |
Tue, 19 August 2008 09:25  |
--------------050602010303070807060906
henrik,
Could you raise a bugzilla entry for this preference issue? It will
require an API change and won't find its way into the 0.8 version. ATM,
a workaround would be to define your own match engine (extension point
org.eclipse.emf.compare.match.engine) for the file extensions you need
(or * with priority set higher than "lowest" if you need this for all
comparisons) and override the option map :
public class SpecificMatchEngine extends GenericMatchEngine {
public MatchModel resourceMatch(Resource leftResource, Resource
rightResource, Map<String, Object> optionMap) throws InterruptedException {
optionMap.put(EMFComparePreferenceKeys.PREFERENCE_KEY_IGNORE _ID, true);
super.resourceMatch(leftResource, rightResource, optionMap);
rightResource, Resource ancestorResource, Map<String, Object> optionMap)
super.resourceMatch(leftResource, rightResource, ancestorResource,
optionMap);
Laurent Goubet
Obeo
Henrik J
Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #620239 is a reply to message #128757] |
Tue, 19 August 2008 06:07  |
--------------020104090201020404070601
Hi Henrik,
I have never tried something like this, and know I haven't implemented
anything of the sort :).
You can try something like :
EMFCompareUIPlugin.getDefault().getPluginPreferences().setVa lue(EMFComparePreferenceKeys.PREFERENCE_KEY_IGNORE_ID,
true);
But I do not know if this can work since the "default" value for this
preference is set to false by EMF Compare.
Laurent Goubet
obeo
Henrik J
Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #620240 is a reply to message #128771] |
Tue, 19 August 2008 07:05  |
true);
Yes, I tried that. But it does not seem to work as you said. Is it
possible to create a extension point to set these default values?
Henrik
Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #620241 is a reply to message #128784] |
Tue, 19 August 2008 08:22  |
--------------090908070206090906020200
No, providing an extension point to set _default_ values seems overkill.
What exactly is the need behind this? I could change the
GenericMatchEngine to allow preferences overriding if this could solve
the issue.
Laurent Goubet
Obeo
Henrik J
Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #620242 is a reply to message #128792] |
Tue, 19 August 2008 09:09  |
My users are signalling engineers, not programmers. When my RCP product
starts I want to set the OPTION_IGNORE_ID to true so that they can compare
our models files directly in the UI. I don't want them to first go into
Window->Preferences->EMF Compare and change a setting they don't
understand. They want to compare model files fast and easily.
> I could change the GenericMatchEngine to allow preferences overriding if
> this could solve the issue.
Yes, that might be an good option.
Henrik
Re: [Compare] Set the OPTION_IGNORE_ID upon startup? [message #620243 is a reply to message #128805] |
henrik,
optionMap);
Laurent Goubet
Obeo
Henrik J
FUDForum. Page generated in 0.11382 seconds
