Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMOF to Ecore
EMOF to Ecore [message #128428] |
Fri, 08 August 2008 04:11  |
I have an EMOF file in the XML format.I need to convert this into the
ECORE format.
A small snippet of the code is given below:
<emof:Package xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmi:id="xyz"
name="xyz" >
Is there any tool,which can accept this format and give the corresponding
ecore relevant code.
If there is no tool and if I have to do it manually,how do I proceed.
Please help me in solving this issue.
Swetha.
Re: EMOF to Ecore [message #128559 is a reply to message #128520] |
Mon, 11 August 2008 07:00   |
--------------010407090007000209070704
Swetha,
Comments below.
Swetha wrote:
> Hi Ed,
> Thanks for your reply.
> I tried the following.
> 1.Initially I had the test.xml file which is in XML format.
Not sure what XML format means.
> 2.I did a File Save As and saved it in the ecore format.
You saved with a *.ecore extension using the Sample Ecore Editor which
has this logic:
public void doSaveAs()
SaveAsDialog saveAsDialog= new SaveAsDialog(getSite().getShell());
saveAsDialog.create();
saveAsDialog.setMessage(EcoreEditorPlugin.INSTANCE.getString ( "_UI_SaveAs_message"));
saveAsDialog.open();
IPath path= saveAsDialog.getResult();
if (path != null)
IFile file =
ResourcesPlugin.getWorkspace().getRoot().getFile(path);
if (file != null)
ResourceSet resourceSet = editingDomain.getResourceSet();
Resource currentResource = resourceSet.getResources().get(0);
String currentExtension =
currentResource.getURI().fileExtension();
URI newURI =
URI.createPlatformResourceURI(file.getFullPath().toString(), true);
String newExtension = newURI.fileExtension();
if (currentExtension.equals(ECORE_FILE_EXTENSION) &&
newExtension.equals(EMOF_FILE_EXTENSION) ||
currentExtension.equals(EMOF_FILE_EXTENSION) &&
newExtension.equals(ECORE_FILE_EXTENSION))
Resource newResource = resourceSet.createResource(newURI);
newResource.getContents().addAll(currentResource.getContents ());
resourceSet.getResources().remove(0);
resourceSet.getResources().move(0, newResource);
else
currentResource.setURI(newURI);
IFileEditorInput modelFile = new FileEditorInput(file);
setInputWithNotify(modelFile);
setPartName(file.getName());
doSave(getActionBars().getStatusLineManager().getProgressMon itor());
> 3.I tried opening this ecore file using EMF .
> 4.While loading the Ecore,the following Exception has been thrown.
> !ENTRY org.eclipse.emf.importer 2 0 2008-08-11 09:27:24.274
> !MESSAGE Class 'Package' not found.
> (platform:/resource/TestEMF/model/test.ecore, 4, 22)
> !STACK 0
> org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'Package' not
> found. (platform:/resource/TestEMF/model/test.ecore, 4, 22)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2229)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2220)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1318)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1454)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
> at
> org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
> I am not sure just by saving the emof file(in xml format) into
> ecore format works for me.
It didn't seem to work.
> Have I missed something here.
I guess so. It worked fine for me when I just tried it. You used the
Sample Ecore Editor?
> I am currently using Eclipse Ganymede V3.4
> Plz advice.
> Regards,
> Swetha.
<html>
<head>
http-equiv="Content-Type">
</head>
Swetha,<br>
<br>
Comments below.<br>
<br>
Swetha wrote:
<blockquote
cite="mid:00ee2974a514f91390e0d3e40aab0fe1$1@www.eclipse.org"
type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
Not sure what XML format means.<br>
<blockquote
type="cite"><br>
<br>
</blockquote>
has this logic:<br>
<blockquote>
Re: EMOF to Ecore [message #128732 is a reply to message #128720] |
Wed, 13 August 2008 06:49  |
Swetha,
If you have the full EMF installed (as available in the Ganymede
modeling package or from the EMF download package) it comes with the
Sample Ecore Editor; you'll see that choice on the Open With menu. I
can't comment informatively on what's in various other distros...
Swetha wrote:
> Hi Ed,
> I am using the TOPCASED Ver 2.0 M6.This has the Sample Ecore Editor. I
> hope it's the same editor you are referring. If its not correct, can
> you please tell me the link where I can download Sample Ecore Editor.
> Regards,
> Swetha.
Re: EMOF to Ecore [message #620216 is a reply to message #128428] |
Fri, 08 August 2008 08:20  |
Swetha,
EMOFResourceFactoryImpl creates resources implementations configured to
do this. Even the Sample Ecore Editor can do this. I.e., it can open a
*.emof file and if you do a "Save As" to a *.ecore name, it will save it
in Ecore format instead of EMOF format (or vice versa as well). With
the content type support in EMF 2.4, we've even registered the EMOF
content type for *.xmi extension so we should be able to read that...
I saw your questions on one of the other newsgroups. Likely those folks
should be supporting this directly and perhaps just need to tweak some
configuration to make it work. EMOF serializations should just be
transparently handles as an interchangeable format for Ecore...
Swetha wrote:
> ECORE format.
> name="xyz" >
> corresponding ecore relevant code.
> Swetha.
Re: EMOF to Ecore [message #620222 is a reply to message #128442] |
Mon, 11 August 2008 00:37  |
Hi Ed,
!STACK 0
at
at
at
at
at
at
at
at
at
I am not sure just by saving the emof file(in xml format) into ecore
format works for me.Have I missed something here.
Plz advice.
Swetha.
Re: EMOF to Ecore [message #620225 is a reply to message #128520] |
Swetha,
Comments below.
Swetha wrote:
> Hi Ed,
has this logic:
if (path != null)
IFile file =
if (file != null)
URI newURI =
else
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Plz advice.
> Regards,
> Swetha.
<html>
<head>
</head>
Swetha,<br>
<br>
Comments below.<br>
<br>
Swetha wrote:
<blockquote
type="cite">Hi Ed,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<blockquote
type="cite"><br>
<br>
</blockquote>
has this logic:<br>
<blockquote>
Re: EMOF to Ecore [message #620235 is a reply to message #128559] |
Wed, 13 August 2008 05:47  |
Hi Ed,
hope it's the same editor you are referring. If its not correct, can you
Swetha.
Re: EMOF to Ecore [message #620236 is a reply to message #128720] |
Swetha,
Swetha wrote:
> Hi Ed,
> Regards,
> Swetha.
Current Time: Sun Jul 20 21:07:32 EDT 2025
Powered by FUDForum. Page generated in 0.04955 seconds
