Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Store] Re-connection to server
[EMF Store] Re-connection to server [message #1283462] Thu, 03 April 2014 08:53 Go to next message
Hello everyone !
I'm having some problems using EMF Store as an internal model database for my RCP application (e4 ! Cool )
I'm doint all the stuff programmaticaly, on the launch of my application.
On the first launch, I create a new server, a new project, I share the project to the server, and I commit some changes after populating the model.
Until now, everything works pretty well !
BUT,
The second step is on a future launch of my application. I want to get the previously committed model.
So I search for the server using his name, I get the remote project and I try to checkout it in a fresh local project.
BOOM
I'm getting :
Usersession not logged in. Login first
So I use the previous user session to log in.
Then I get :
Server could not be reached. Failed to read server's response: Connection refused: connect
After that, I don't know what I could do. Any hint ?
Thanks in advance
Flo
[Updated on: Thu, 03 April 2014 09:36] by Moderator
Re: [EMF Store] Re-connection to server [message #1284286 is a reply to message #1283462] Fri, 04 April 2014 05:51 Go to previous messageGo to next message
Hi Flo,
how exactly do you try to login the previous usersession?
If you call getLastUserssesion() on the ESServer instance you will
get back the most recent usersession, which successfully was logged in.
You may then call refresh() on it to log it in again.
Note that you can only do so, if you previously set the usersession to
save the password by calling setSavePassword(true) on the ESUsersession.
EMFstore does not save passwords by default and keeps requesting them if
setSavePassword hasn't been specified.
Hope this helps,
Cheers
Edgar
Am 03.04.2014 15:19, schrieb Flo Dubois:
> Hello everyone !
> for my RCP application (e4 ! 8) )
> model.
> Until now, everything works pretty well ! BUT,
> BOOM
> I'm getting : "Usersession not logged in. Login first".
> Then I get : "Server could not be reached. Failed to read server's
> response: Connection refused: connect"
> Thanks in advance
> Flo
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMF Store] Re-connection to server [message #1287184 is a reply to message #1284286] Mon, 07 April 2014 09:58 Go to previous message
Hi Edgar,
Thank you for your answer ! I was already doing things this way.
The best is to show you my code.
First the first launch, this code works well :
private void firstLaunch() throws IOException, ESException, ESServerStartFailedException
      workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
      System.out.println("Delete workspace servers");
      for (ESServer existingServer : workspace.getServers())
         try
            workspace.removeServer(existingServer);
         catch (ESServerNotFoundException e)
            e.printStackTrace();
      System.out.println("Delete workspace projects");
      for (ESLocalProject existingLocalProject : workspace.getLocalProjects())
         existingLocalProject.delete(new ESSystemOutProgressMonitor());
      System.out.println("Create and add a new server");
      localServer = ESServer.FACTORY.createAndStartLocalServer();
      localServer.setPort(8080);
      workspace.addServer(localServer);
      System.out.println("Create a new user session");
      usersession = localServer.login("super", "super");
      usersession.setSavePassword(true);
      System.out.println("Create new project : myProject");
      project = workspace.createLocalProject("myProject");
      System.out.println("Share the project : " + project.getProjectName());
      remoteProject = project.shareProject(usersession, new ESSystemOutProgressMonitor());
      Synchronizer.retrieveDataFromRemoteServer(project); // custom data retriever
      project.commit(new ESSystemOutProgressMonitor());
For everyday launches then, this code doesn't works :
private void normalLaunch() throws ESException, IOException
      if (workspace.getServers().size() > 0)
         System.out.println("Get the previously created server");
         localServer = workspace.getServers().get(0); // get the local server already created
      usersession = localServer.getLastUsersession();
      if (usersession == null)
         System.out.println("Previous session not found");
      else
         System.out.println("Found previous session");
      System.out.println("usersession.isLoggedIn() = " + usersession.isLoggedIn());
      System.out.println("usrSession.getUsername() = " + usersession.getUsername());
      System.out.println("usrSession.getPassword() = " + usersession.getPassword());
      usersession.refresh();
      remoteProject = localServer.getRemoteProjects().get(0);
      for (ESRemoteProject rp : localServer.getRemoteProjects(usersession))
         System.out.println("remote project found : " + rp.getProjectName());
      // usersession = localServer.login("super", "super");
      project = remoteProject.checkout("myProject", usersession, new ESSystemOutProgressMonitor());
I'm still getting the error :
org.eclipse.emf.emfstore.internal.server.exceptions.ConnectionException: Server could not be reached.
just when I try the usersession.refresh();
All what I want is just a local server store, storing locally my model in my computer. The server should start with my custom application, checkout the previous model, and stop when my application turns off.
Again, thank you,
Flo
Previous Topic:[EMFStore] Mixed environment problem
Next Topic:ECP Static UI widgets into Editor
Current Time: Mon Jul 28 17:45:22 EDT 2025
Powered by FUDForum. Page generated in 0.03391 seconds
