Home » Archived » Visual Editor (VE) » java.lang.NullPointerException in VE
java.lang.NullPointerException in VE [message #128547] Wed, 12 July 2006 09:44 Go to next message
Originally posted by: steven.arnott.philips.com
I recently opened an Java GUI project with Eclipse 3.2
(VE 1.2, GEF 3.2, EMF 2.2.0) on a Windows XP platform..
(JDK 1.5.0_07)
The main GUI display properly with Eclipse 3.2..
However now I get:
at
org.eclipse.ve.internal.java.codegen.model.BeanPart.getSimpl eName(BeanPart.java:273)
at
org.eclipse.ve.internal.java.codegen.model.BeanPart.getImpli citName(BeanPart.java:282)
at
org.eclipse.ve.internal.java.codegen.model.BeanPart.getSimpl eName(BeanPart.java:276)
at
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.get UnreferencedBeanParts(BeanDeclModel.java:791)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.buildCompositionModel(JavaSourceTranslator.java:765)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:874)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:947)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Any ideas what I should look for in the code?
Steven
Re: java.lang.NullPointerException in VE [message #128585 is a reply to message #128547] Wed, 12 July 2006 10:06 Go to previous messageGo to next message
Somebody else just had this problem.
Do you have code that looks something like this:
JECFrame extends JFrame {
private JECFrame thisFrame = null;
JECFrame() {
thisFrame = this;
somemethod() {
thisFrame.getRootPanel()....
If you do, get rid of thisFrame and use this. in its place everywhere
that you were using thisFrame.
If not, please send me a copy of the class. You can send directly to me,
you don't need to attach to the newsgroup.
Rich Kulp
Re: java.lang.NullPointerException in VE [message #128598 is a reply to message #128585] Wed, 12 July 2006 10:20 Go to previous messageGo to next message
HI Rich,
The GUI was built with Eclipse from scratch, so I don't believe that it
does what your suggest...
Due to company "firewall" rules I'm reading this via the Eclipse.org web
interface, so not sure where to get your email address from?
Steven
> JECFrame() {
> thisFrame = this;
> somemethod() {
Re: java.lang.NullPointerException in VE [message #128610 is a reply to message #128598] Wed, 12 July 2006 11:32 Go to previous messageGo to next message
My address to use is richkulp@us. ibm.com (remove the spaces
between us. and ibm.com, this is just so I don't put my full email into
the note).
Rich Kulp
Re: java.lang.NullPointerException in VE [message #128786 is a reply to message #128610] Thu, 13 July 2006 10:32 Go to previous messageGo to next message
This is due to an outstanding bug where we were too aggressive in
parsing code.
It looks weird but change the code:
if (metaFile.exists() && metaFile.canRead()) {
myMDGui.getMyMDI().initaliseMDI(false,metaFile,topCell.getNa me());
} else {
myMDGui.getMyMDI().initaliseMDI(true,metaFile,topCell.getNam e());
to:
if (false)
else if (metaFile.exists() && metaFile.canRead()) {
} else {
We don't parse the "else" clause of if statements. The
myMDGui.getMyMDI() was causing problems. So by using this code pattern
it is put into the else clause so that the VE won't parse it. But at
runtime it will work fine. The compiler is smart enough to compile out
the if (false) ; part and just go right to the else clause.
Rich Kulp
Re: java.lang.NullPointerException in VE [message #128836 is a reply to message #128786] Fri, 14 July 2006 04:19 Go to previous messageGo to next message
Many thanks for this Rich...
It now lets me get on with updates to the GUI..
Steven
Re: java.lang.NullPointerException in VE [message #133229 is a reply to message #128836] Thu, 16 November 2006 14:51 Go to previous messageGo to next message
Originally posted by: jhigh.ewation.co.za
I have encountered the same exception although my situation is rather
different.
I have a member variable which is an instance of the bean containing the
bean failing to parse (ie the Parent Panel). As soon as I declare that
member variable and initialise it to null I get this exception.
Any ideas?
Re: java.lang.NullPointerException in VE [message #133254 is a reply to message #128585] Fri, 17 November 2006 10:39 Go to previous messageGo to next message
> JECFrame() {
> thisFrame = this;
> somemethod() {
I had something like that in mine where static methods referred to
thisFrame and a couple non-static methods did, too. But changing the
non-static methods to just call "getRootPanel()" etc. didn't help. The
VE just shows a red X over 'this-"JFrame"' and
'java.lang.NullPointerException(null)' at the bottom of the window.
Is there a way to get more detail on the exception?
This is on Linux with Java 1.5.0_07 in eclipse 3.2.1. VE
1.2.0.v20060518_RC1. I just installed it this week, is it really still RC1?
Rick
Re: java.lang.NullPointerException in VE [message #133266 is a reply to message #133254] Fri, 17 November 2006 12:59 Go to previous messageGo to next message
>> JECFrame() {
>> thisFrame = this;
>> somemethod() {
>> me, you don't need to attach to the newsgroup.
> RC1?
Oops, found the log:
eclipse.buildId=M20060629-1905
java.version=1.5.0_07
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
Error
Fri Nov 17 12:40:47 EST 2006
Failed to execute runnable (java.lang.NullPointerException)
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3143)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2845)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at
org.eclipse.ve.internal.java.core.BeanPropertyDescriptorAdap ter.isReadOnly(BeanPropertyDescriptorAdapter.java:463)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:803 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1029)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:943)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:473)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
.... 20 more
Rick
Re: java.lang.NullPointerException in VE [message #133279 is a reply to message #133254] Fri, 17 November 2006 13:18 Go to previous messageGo to next message
> RC1?
OK, I seem to have cleared it up. I found this generated code:
private JScrollPane getR6GuiCommandOutputScrollPane()
if (r6GuiCommandOutputScrollPane == null) {
r6GuiCommandOutputScrollPane = new JScrollPane();
r6GuiCommandOutputScrollPane.setPreferredSize(new
Dimension(733, 182));
r6GuiCommandOutputScrollPane.setViewportView(getCommandOutpu t());
r6GuiCommandOutputScrollPane.setComponentOrientation(Compone ntOrientation.LEFT_TO_RIGHT);
return r6GuiCommandOutputScrollPane;
I deleted the second setComponentOrientation() line. That caused
another NullPointerException and nothing at all could be displayed in
the VE. I restored the line and opened the JFrame in VE again, and it
seems OK now. What's that about?
Rick
Re: java.lang.NullPointerException in VE [message #133368 is a reply to message #128547] Thu, 23 November 2006 07:16 Go to previous messageGo to next message
Hi There,
i'm having the same problem with VE, but it happens with any swing VE class. I'm under windows 2000, JDK 1.5.0_09 and eclipse 3.2. I'm sending the log file below. Any ideas?
!ENTRY org.eclipse.ve.java.core 2 0 2006-11-23 10:15:47.281
!MESSAGE
+++ Warning +++: Thu Nov 23 10:15:47 GMT-03:00 2006 Skipping expression: jContentPane.setLayout(null)
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-23 10:15:47.281
!MESSAGE Invalid PropertyDecorator
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-23 10:15:47.781
!MESSAGE Exception thrown.
!STACK 0
at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:779)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:1115)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:610)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:595)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:587)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:582)
at org.eclipse.ve.internal.jfc.core.ContainerGraphicalEditPart. createLayoutEditPolicy(ContainerGraphicalEditPart.java:83)
at org.eclipse.ve.internal.jfc.core.ContainerGraphicalEditPart. createEditPolicies(ContainerGraphicalEditPart.java:69)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:230)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:554)
at org.eclipse.ve.internal.cde.core.CDEAbstractGraphicalEditPar t.refresh(CDEAbstractGraphicalEditPart.java:338)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:504)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2098)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-23 10:15:47.796
!STACK 0
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:833)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:818)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1103)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2458)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1032)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:918)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2178)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1386)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:86)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:553)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:233)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:203)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:993)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:881)
at org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.primDoSave(JavaSourceTranslator.java:1397)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1411)
at org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$3.doRun(JavaSourceTranslator.java:956)
at org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
!ENTRY org.eclipse.ui 4 4 2006-11-23 10:15:47.796
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-11-23 10:15:47.796
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
... 20 more
Thanks a lot.
Re: java.lang.NullPointerException in VE [message #133381 is a reply to message #128547] Thu, 23 November 2006 07:22 Go to previous messageGo to next message
Nevermind, i already found the error. Thanks anyway.
Re: java.lang.NullPointerException in VE [message #133653 is a reply to message #133381] Tue, 28 November 2006 09:17 Go to previous messageGo to next message
I found that by moving to a strict Model-View-Controller design anything
that's going to confuse VE is no longer in a Java bean. Haven't had any
problems since. Of course, the first problem seemed to be due to a line
getting generated twice when updating a property so presumably that
could happen again.
Should this be a FAQ? Something like:
Q: How do I avoid getting NullPointerExceptions when updating the
generated code manually?
A: VE can get confused when you manipulate bean properties without
going through the Properties editor. Move those operations to a class
in another file and call its methods from the bean.
Rick
Re: java.lang.NullPointerException in VE [message #133665 is a reply to message #133653] Tue, 28 November 2006 10:14 Go to previous message
Rick is right. The best approach is MVC. Don't put business logic into
the UI. The UI should be simply handling display and sending events. Any
logic to control the UI should be in another class. This isn't only the
best for the VE, it is in general the best pattern to use.
> could happen again.
Rich Kulp
Re: java.lang.NullPointerException in VE [message #613528 is a reply to message #128547] Wed, 12 July 2006 10:06 Go to previous message
JECFrame() {
thisFrame = this;
somemethod() {
Rich Kulp
Re: java.lang.NullPointerException in VE [message #613529 is a reply to message #128585] Wed, 12 July 2006 10:20 Go to previous message
HI Rich,
Steven
> JECFrame() {
> thisFrame = this;
> somemethod() {
Re: java.lang.NullPointerException in VE [message #613530 is a reply to message #128598] Wed, 12 July 2006 11:32 Go to previous message
the note).
Rich Kulp
Re: java.lang.NullPointerException in VE [message #613544 is a reply to message #128610] Thu, 13 July 2006 10:32 Go to previous message
parsing code.
} else {
to:
if (false)
} else {
Rich Kulp
Re: java.lang.NullPointerException in VE [message #613548 is a reply to message #128786] Fri, 14 July 2006 04:19 Go to previous message
Steven
Re: java.lang.NullPointerException in VE [message #614787 is a reply to message #128836] Thu, 16 November 2006 14:51 Go to previous message
different.
Any ideas?
Re: java.lang.NullPointerException in VE [message #614789 is a reply to message #128585] Fri, 17 November 2006 10:39 Go to previous message
> JECFrame() {
> thisFrame = this;
> somemethod() {
Rick
Re: java.lang.NullPointerException in VE [message #614790 is a reply to message #133254] Fri, 17 November 2006 12:59 Go to previous message
>> JECFrame() {
>> thisFrame = this;
>> somemethod() {
> RC1?
Error
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
.... 20 more
Rick
Re: java.lang.NullPointerException in VE [message #614791 is a reply to message #133254] Fri, 17 November 2006 13:18 Go to previous message
> RC1?
Rick
Re: java.lang.NullPointerException in VE [message #614798 is a reply to message #128547] Thu, 23 November 2006 07:16 Go to previous message
Hi There,
!MESSAGE
!STACK 0
!STACK 0
!STACK 0
... 20 more
Thanks a lot.
Re: java.lang.NullPointerException in VE [message #614799 is a reply to message #128547] Thu, 23 November 2006 07:22 Go to previous message
Re: java.lang.NullPointerException in VE [message #614820 is a reply to message #133381] Tue, 28 November 2006 09:17 Go to previous message
could happen again.
Rick
Re: java.lang.NullPointerException in VE [message #614821 is a reply to message #133653] Tue, 28 November 2006 10:14 Go to previous message
> could happen again.
Rich Kulp
Previous Topic:How to create widgets in VE with respect to eSWT
Next Topic:VE problem
Current Time: Sat Jul 19 04:10:37 EDT 2025
Powered by FUDForum. Page generated in 0.06500 seconds
