Deep copy of model element [message #1283477] |
Thu, 03 April 2014 09:07  |
I am an Epsilon beginner, and am currently getting started by writing the classic Pull Up Attribute refactoring in ETL on a UML Class Diagram. My model is a UML model ("source.uml") created using Papyrus.
This is an endogenous transformation and I'm currently attempting an out-place approach - generating a separate output model "target.uml". As a first step, I should first be able to do something simple: copy the model in "source.uml" to "target.uml". However, I got stuck at this point. It is not clear to me whether I need to write an ETL rule for every model element type in "source.uml" - in UML, these can be quite a lot. Furthermore, do I then need to manually copy each property of each model element withing this rule? This seems like a lot of work, and also seems to lose the model structure - if I have a rule for instances of Property, Properties are created in the target model separately from any Class element.
Is there some kind of "deep copy" operator to allow copying e.g. a Class in the source model to the target model together with all of its Properties? Or just copy an entire Model as it is?
Thanks in advance,
Vlad
FUDForum. Page generated in 0.07473 seconds
