ECP Validation not working if running as part of Kepler Workbench [message #1283660] |
Thu, 03 April 2014 13:32  |
Hello There
When i run your makeithappen as explained in your example using e4 demo feature and then required plugins, then when i open the ECP Editor, i see the required fields appearing in RED with ! mark
I am working on creating a custom kepler workbench thru my product configuration.
I have included all the ECP related plugins and able to run and view Model Explorer and Model Repositories view. But when i open the ECP Editor, i dnt see the required fields marked in RED with ! mark.
Can you please tell me what am i missing ? I dnt seem to have left out any ECP Plugin in my Product Configuration. It would be great if you can share a kepler workbench product configuration for ECP and other minimum Modelling Plugins otherwise.
Malai
Re: ECP Validation not working if running as part of Kepler Workbench [message #1299851 is a reply to message #1284220] |
Thu, 17 April 2014 02:44   |
Hey Jonas
As explained, after adding features and validating my .product file, i
got validation errors stating emfstore.client is missing. I had to add
the emfstore plugins from EMF in the plugins configuration instead of
features as i couldnt find the features for emf.emfstore to make it run.
I am attaching the .product and also the launch configuration for ur ref.
hope this helps.
regards
malai
On 4/4/2014 1:40 PM, Jonas Helming wrote:
> I strongly recommend to configure the product feature based, this is
> much more convenient. As an example, you could just add the ECP SDK to
> your product. The bundle you are currently missing is ecp.view.validation
> Best Regards
> Jonas
> Am 03.04.2014 19:32, schrieb Annamalai Chockalingam:
>> Hello There
>> configuration.
>> Regards
>> Malai
Re: ECP Validation not working if running as part of Kepler Workbench [message #1300757 is a reply to message #1299851] |
Thu, 17 April 2014 16:00  |
Bug is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=432974
Am 17.04.2014 08:44, schrieb Annamalai:
> Hey Jonas
> hope this helps.
> regards
> malai
>> Hi,
>> ecp.view.validation
>> Best Regards
>> Jonas
>>> Hello There
>>> configuration.
>>> Regards
>>> Malai
FUDForum. Page generated in 0.10455 seconds
