Home » Archived » Test and Performance Tools Platform (TPTP) » failed to redefine 1 classes. JVMTI Error: 62
failed to redefine 1 classes. JVMTI Error: 62 [message #128347] Sat, 12 April 2008 09:54 Go to next message
Originally posted by: cap_nemesis.hotmail.com
I am trying to profile a web app using tomcat as standalone app and the
agent controller.
this is what I've found in the logs:
Informative 04/12/08 09:58:23 640 0 CJVMTIInterface RedefineClasses: failed
Error 04/12/08 09:58:23 640 0 CJavaInstrumentorManager RedefineClasses
failed. Instrumented classes may be in inconsistent state".
How do I find the class that is causing the problem, so I could try to
filter it out.
Markus
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #128371 is a reply to message #128347] Sun, 13 April 2008 06:00 Go to previous messageGo to next message
Markus Kühn wrote:
> agent controller.
> filter it out.
Please specify the following information so we can better help:
1. Operating system version
2. Architecture (IA-32, AMD64/Intel EM64T, etc...)
3. TPTP Version
4. Agent Controller version
5. Java version (type java -version to check...)
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #128397 is a reply to message #128371] Sun, 13 April 2008 13:54 Go to previous messageGo to next message
1. Operating system version:
Windows XP SP2
2. Architecture (IA-32, AMD64/Intel EM64T, etc...) IA-32
3. TPTP Version
TPTP-4.4.1
Version unkown; Filename: agntctrl.win_ia32-TPTP-4.4.1.zip
SUN JDK 1.5.0_15
I hope this helps,
Markus
Mit freundlichen Gr
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #129612 is a reply to message #128397] Tue, 29 April 2008 04:19 Go to previous messageGo to next message
Markus,
Can you please post the full log file (MLog*.log) to this newsgroup?
Asaf
Asaf Yaffe
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131070 is a reply to message #128397] Tue, 10 June 2008 16:40 Go to previous messageGo to next message
Originally posted by: chad.moller.objectpartners.com
Has anyone solved this problem? I am having the same issue, but I am using
the IAC and starting tomcat from Eclipse. Any assistance would be greatly
appreciated.
1. Operating system version: Windows XP SP2
2. Architecture: Intel EM64T
3. TPTP Version: TPTP-4.4.1
4. Agent Controller version - na
5. Java version SUN JDK 1.5.0_14
The last 15 lines of my log -
Informative 06/10/08 20:13:29 2408 5 CJVMTIInterface [ClassFileLoadHookHandler]
com/esri/adf/web/util/ADFServletContextListener, class loader = 00837014
java/lang/VerifyError, class loader = 00000000
Informative 06/10/08 20:13:29 2408 5 CDataManager Updated instrumentation
information for method '<init>(()V)' (id = 111091)
information for method '<init>((Ljava/lang/String;)V)' (id = 111092)
information for class 'java/lang/VerifyError' (id = 4851)
Informative 06/10/08 20:13:29 2408 3 CGAdaptor Class java/lang/VerifyError
was not instrumented because all its methods were excluded
Informative 06/10/08 20:13:29 2408 5 CJavaInstrumentorManager Using basic
instrumentation for class 4851 'java/lang/VerifyError'
Informative 06/10/08 20:13:29 2408 5 CJavaInstrumentorManager Instrumented
class 4851 'java/lang/VerifyError' will be returned to JVM
Informative 06/10/08 20:13:29 2408 5 CJVMTIInterface ClassPrepare event
received: class = 'Ljava/lang/VerifyError;', generic = '(null)'
Informative 06/10/08 20:13:29 2408 0 CDataManager Class
'java/lang/VerifyError' has wrong instrumentation, but will not be
redefined due to user-defined filters or an internal reason
Informative 06/10/08 20:13:29 2408 0 CJVMTIInterface RedefineClasses:
Error 06/10/08 20:13:29 2408 0 CJavaInstrumentorManager RedefineClasses
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131369 is a reply to message #131070] Tue, 17 June 2008 09:27 Go to previous messageGo to next message
Chad,
Can you please compress and post the full log file?
Asaf
Asaf Yaffe
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131410 is a reply to message #131369] Tue, 17 June 2008 16:48 Go to previous messageGo to next message
<sarcasm>I'm getting told that we can't post the log file because it contains
ultra-sensitive information about our company such as class names </sarcasm>
Is there something specific I can look for that might help you? Or, if I
scrubbed all of our internal class names, would the file still be
valuable?
Thanks for your help!!
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131422 is a reply to message #131410] Wed, 18 June 2008 04:40 Go to previous messageGo to next message
> contains ultra-sensitive information about our company such as class
> names </sarcasm>
> scrubbed all of our internal class names, would the file still be valuable?
The whole point in checking the log file is to determine which class
causes the JVMTI error :)
Can you please try to reproduce this error with the latest Release
Candidate version of TPTP 4.5 (download available in the TPTP web site
at http://www.eclipse.org/tptp). We have made several changes in this
version related to these issues, and you may find this version more
stable. Note that TPTP 4.5 requires Eclipse 3.4. A full list of
prerequisites is available in the TPTP download page.
Asaf
Asaf Yaffe
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131473 is a reply to message #131422] Wed, 18 June 2008 17:22 Go to previous messageGo to next message
I will upgrade my Eclipse and TPTP installs and see what happens. If this
doesn't work, is it possible to get your personal contact information? I
might be able to get permission to give you the log file, but it sounds
like posting it publicly would be absolutely impossible.
Re: failed to redefine 1 classes. JVMTI Error: 62 [message #131918 is a reply to message #131473] Tue, 01 July 2008 10:29 Go to previous message
> this doesn't work, is it possible to get your personal contact
> information? I might be able to get permission to give you the log file,
> but it sounds like posting it publicly would be absolutely impossible.
As it publicly appears in the "from" field of this message, my contact
information is asaf dot yaffe at intel dot com.
Asaf
Asaf Yaffe
Previous Topic:Agent Controller is not active
Next Topic:TPTP not showing all expected object
Current Time: Wed Jul 23 18:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.05330 seconds
