Home » Eclipse Projects » Remote Application Platform (RAP) » CVS plugins and compilation errors
CVS plugins and compilation errors [message #128301] |
Thu, 16 April 2009 14:01  |
Originally posted by: benjamin.wolff.web.de
i'm using the latest CVS HEAD of the RAP plugins.
the plugins org.eclipse.rap.jface and org.eclipse.rap.ui.workbench are having compile errors
saying that some private constructors are never used locally. these errors are causing the following
exception when starting the application:
java.lang.RuntimeException: Could not create the session singleton instance of 'org.eclipse.ui.internal.WorkbenchPlugin$ThemeRegistryStore' because an Exception was thrown by the constructor:
Unresolved compilation problems:
The constructor WorkbenchPlugin.ThemeRegistryStore() is never used locally
The constructor WorkbenchPlugin.WorkingSetRegistryStore() is never used locally
at org.eclipse.rwt.SessionSingletonBase.getInstanceInternal(Ses sionSingletonBase.java:189)
the project-specific compile options cause unused private members to be handled as an error.
i can overwrite these project-specific options, the exception is not thrown then, but are these
strong compile options actually intended?
greetings,
ben
Re: CVS plugins and compilation errors [message #128328 is a reply to message #128314] |
Thu, 16 April 2009 15:38   |
hmmm, that's odd.
yes, i'm using the /cvsroot/rt plugins. could you check the plugin properties ->
java compiler -> errors/warnings -> unnecessary code.. there are some options set to
'error' in your workspace?!
however the errors have gone after i reverted the plugin to base and then updated from
cvs again. but i didn't change anything in the plugin before, there also wasn't a '>'
before the plugin name...
nevertheless it's gone for now, i was just curious if someone else is experiencing
a similiar problem. thanks!
greetings,
ben
Rüdiger Herrmann schrieb:
> Ben,
> the workbench plug-in is adopted from RCP, so are the compiler settings.
> The intention was to leave things unchanged as much as possible.
> However, I am also working against CVS HEAD and do not have any errors.
> Are you sure that you checked out from the /cvsroot/rt repository?
> HTH
> Rüdiger
> Ben W. wrote:
>> Hi,
>> instance of
>> Unresolved compilation problems: The constructor
>> used locally
>> at
>> greetings,
>> ben
Re: CVS plugins and compilation errors [message #128340 is a reply to message #128328] |
Thu, 16 April 2009 16:05   |
Ben W. wrote:
> hmmm, that's odd.
> properties ->
> options set to
yes, they are set to 'error'
> then updated from
> wasn't a '>'
strange, indeed.
> experiencing
Sorry, I can't help here. For me, it works out of the box.
> greetings,
> ben
>> Ben,
>> settings. The intention was to leave things unchanged as much as
>> possible.
>> HTH
>> Rüdiger
>> Ben W. wrote:
>>> Hi,
>>> instance of
>>> never used locally
>>> at
>>> greetings,
>>> ben
Re: CVS plugins and compilation errors [message #128379 is a reply to message #128328] |
Thu, 16 April 2009 16:34   |
> properties ->
> options set to
Obviously, some new compiler preferences have been introduced with
Eclipse 3.5 M6. These are still missing in our plugin preferences and
the aggressive defaults seem to cause these errors. I guess we'll need
to update our preferences files.
Still strange that we only see those errors for these two plug-ins.
> then updated from
> wasn't a '>'
Strange. Still with M6 and didn't change your workspace settings?
Ralf
>> Ben,
>> possible.
>> HTH
>> Rüdiger
>> Ben W. wrote:
>>> Hi,
>>> instance of
>>> never used locally
>>> at
>>> greetings,
>>> ben
Re: CVS plugins and compilation errors [message #128392 is a reply to message #128340] |
Thu, 16 April 2009 16:41   |
One thing which came to my mind when I read the questions:
The JDT/Core compiler had a bug which manifested itself as a too strict
"dead code" detection.
As far as I remember this is gone in 3.5M6. Do you use the Eclipse
milestone builds?
Rüdiger Herrmann wrote:
> Ben W. wrote:
>> hmmm, that's odd.
>> properties ->
>> options set to
>> then updated from
>> also wasn't a '>'
> strange, indeed.
>> experiencing
>> greetings,
>> ben
>>> Ben,
>>> possible.
>>> HTH
>>> Rüdiger
>>> Ben W. wrote:
>>>> Hi,
>>>> instance of
>>>> never used locally
>>>> at
>>>> greetings,
>>>> ben
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: CVS plugins and compilation errors [message #128405 is a reply to message #128379] |
Thu, 16 April 2009 17:11  |
hi,
yes ralf, i'm using the latest eclipse milestone (build-id: I20090313-0100).
it's getting more strange, looking at the class org.eclipse.jface.util.Assert
the public constructor AssertionFailedException() is marked as never used locally with
an error. the project, however, only reports warning and compiles well. sometime these
'used locally' warnings are threated as fata compile errors and sometimes they aren't.
didn't change any of my workspace options...
this might even originate from an eclipse jdt bug, but since this issue, if it occurs,
can be easily solved by overriding the project specific compile warnings/erros it shouldn't
break any applications working against cvs head.
thx for your hints!
greetings,
ben
Ralf Sternberg schrieb:
>> properties ->
>> options set to
>> then updated from
>> wasn't a '>'
> Cheers,
> Ralf
>>> Ben,
>>> possible.
>>> HTH
>>> Rüdiger
>>> Ben W. wrote:
>>>> Hi,
>>>> instance of
>>>> never used locally
>>>> at
>>>> greetings,
>>>> ben
Current Time: Wed Jul 23 12:22:25 EDT 2025
Powered by FUDForum. Page generated in 0.10132 seconds
