Home » Modeling » M2T (model-to-text transformation) » [Acceleo] No output despite correct input
[Acceleo] No output despite correct input [message #1281755] Tue, 01 April 2014 05:57 Go to next message
I'm having some problems with an Acceleo plugin I am working on. the plugin should generate some output files based on the output of some QVTO transformations. I have adapted the generateAll method of one of the template UI plugins to achieve this, and if I execute the plugin using 'run as->Eclipse application', everything appears to be working fine.
However, if I 'Export->Deployable fragments and plugins->install into host' and then use the plugin, no output is produced, and I get the error message:
The generation failed to generate any file because there are no model elements that matches at least the type of the first parameter of one of your main templates.
The problem may be caused by a problem with the registration of your metamodel, please see the method named "registerPackages" in the Java launcher of your generator. It could also come from a missing [comment @main/]
in the template used as the entry point of the generation.
As far as I can tell, the input of the template contains the required elements and there is a @main annotation in the template. I am not explicitely registering metamodels, but the plugin can work without it, so it doesn't seem necessary. As far as I can tell, everything should be working.
My questions are:
* There must be a difference between the two methods of running the plugin. How can I find out what the differences are?
* In general, what is a good method to debug a problem like this?
Arjan van der Meer
Re: [Acceleo] No output despite correct input [message #1282371 is a reply to message #1281755] Wed, 02 April 2014 03:38 Go to previous message
As the comments suggest your plugin registrations are wrong, but often
only understandable with hindsight.
In similar situations I just single step the initialization and see why
the parameters are mismatched.
Ed Willink
On 01/04/2014 10:57, Arjan van der Meer wrote:
> Hello,
> fine. However, if I 'Export->Deployable fragments and plugins->install
> the error message:
> Quote:
>> [comment @main/] in the template used as the entry point of the
>> generation.
> should be working.
> My questions are:
> Regards,
> Arjan van der Meer
Previous Topic:What is the best tool to M2T?
Next Topic:Acceleo - Differences between generations runner
Current Time: Wed Jul 23 03:13:44 EDT 2025
Powered by FUDForum. Page generated in 0.24080 seconds
