Home » Modeling » Epsilon » Add plugin dep to diagram generated code!
Add plugin dep to diagram generated code! [message #1281826] Tue, 01 April 2014 08:11 Go to next message
I am generating edit,editor,diagram plugin code from emfatic file referred in an ant script.
Now I want to add figures ( My custom plugin project ) as req plugin to diagram project (Programatically).
Is there any way in emfactic/ant task todo the same ?
I could see something similar in eol 'var genPlugin = GmfGen!GenPlugin.all.first();
genPlugin.requiredPlugins.add("MyProject.figures");'
but calling eol from ant script is not working as expected for generation!
Shrikanth NC
[Updated on: Tue, 01 April 2014 08:17] by Moderator
Re: Add plugin dep to diagram generated code! [message #1281827 is a reply to message #1281826] Tue, 01 April 2014 08:14 Go to previous messageGo to next message
Hi Shrikanth,
Could you please elaborate a bit more on the behaviour you're observing?
Dimitris
Re: Add plugin dep to diagram generated code! [message #1281833 is a reply to message #1281827] Tue, 01 April 2014 08:23 Go to previous messageGo to next message
RunAnt.xml:33: Undefined variable, type or model: 'GmfGen!GenPlugin' (C:...\model\IS.eol@1:23)
My EOL contains
How my eol knows where my emf file is residing ?
I guess this eol script must be coded with more info.
Shrikanth NC
Re: Add plugin dep to diagram generated code! [message #1281836 is a reply to message #1281833] Tue, 01 April 2014 08:28 Go to previous messageGo to next message
Hi.
Your GmfGen polishing transformation should be specified in a file named "FixGMFGen.eol" in the same directory as your .emf/.ecore metamodel [1] so that Eugenia can pick it up and execute it after its built-in transformation.
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/eugenia-polishing/
[Updated on: Tue, 01 April 2014 08:28] by Moderator
Re: Add plugin dep to diagram generated code! [message #1282304 is a reply to message #1281836] Wed, 02 April 2014 01:16 Go to previous messageGo to next message
Ant Script : which I am invoking programatically :
<target name="main" >
<epsilon.eugenia src="${basedir}/MyProject/model/IS.emf" />
</target>
ECore2GMF.eol content : ( Present in the same directory as my IS.emf )
Console :
Buildfile: C:\Users\shrikanth_n_c\Desktop\epsilonrcp\workspace\MyProject\RunAnt.xml
main:
[epsilon.eugenia] org.eclipse.epsilon.eugenia.ClearGmfFileSetAction@1ef1ae7->true
[epsilon.eugenia] org.eclipse.epsilon.eugenia.Emfatic2EcoreDelegate@1029aa0->true
[epsilon.eugenia] org.eclipse.epsilon.eugenia.Ecore2GenModelDelegate@18244c8->true
[epsilon.eugenia] org.eclipse.epsilon.eugenia.FixGenModelDelegate@fb9cbf->true
BUILD FAILED
C:\Users\shrikanth_n_c\Desktop\epsilonrcp\workspace\MyProject\RunAnt.xml:32: Undefined variable, type or model: 'GmfGen!GenPlugin' (C:\Users\shrikanth_n_c\Desktop\epsilonrcp\workspace\MyProject\model\ECore2GMF.eol@1:23)
Total time: 1 second
My requirement is to add MyProject.figures as dep whenever its generated.
Kindly let me know, What I may be missing!
Shrikanth NC
Re: Add plugin dep to diagram generated code! [message #1282340 is a reply to message #1282304] Wed, 02 April 2014 02:35 Go to previous message
The name of your EOL file should be FixGMFGen.eol instead of ECore2GMF.eol.
Dimitris
Previous Topic:ECL matches operation for Sets
Next Topic:[EGL] Append output to existing file
Current Time: Fri Jul 25 17:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.06998 seconds
