Home » Archived » Visual Editor (VE) » VE & setSize on JPanel class
VE & setSize on JPanel class [message #127697] Wed, 05 July 2006 18:45 Go to next message
Originally posted by: laralar.artinsoft.com
I have a form generator, that basically generates a java class from a text
representation of the form. Here I generete the following line
this.setSize(GridBagLayoutHelper.computeSize(layout, this, 65, 13));
However, when using the VE, and resizing the form, this get replaced by
this.setSize(new Dimension(477, 273));
As you can see, the row/column representation is being changed to the
pixels on the screen.
My question
How could I start to build a customized version of the VE that instead of
changing row/column representation to the pixel dimension, adds or removes
rows and columns? Where do I have to look for?
thanks,
Luis
Re: VE & setSize on JPanel class [message #127710 is a reply to message #127697] Wed, 05 July 2006 19:27 Go to previous messageGo to next message
You can't. You changed the size of the form in the ve. It only knows how
to do setSize of a dimension. Since you changed its size it needed to do
a setSize.
However, why are you using setSize at all? You should be using a layout
manager to do all of this. setSize is very fragile and will not handle
different fonts or languages or resizing the entire shell.
Luis Rodriguez wrote:
> Hello,
> text representation of the form. Here I generete the following line
> My question
> of changing row/column representation to the pixel dimension, adds or
> removes rows and columns? Where do I have to look for?
> thanks,
> Luis
Rich Kulp
Re: VE & setSize on JPanel class [message #127966 is a reply to message #127710] Fri, 07 July 2006 19:12 Go to previous messageGo to next message
Originally posted by: jamesrome.gmail.com
Rich Kulp wrote, On 7/5/2006 7:27 PM:
> a setSize.
When I put a JPanel into the VE in, say the South of the default Border Layout
Manager, it has zero size, and I cannot put other components into it until I set
its size. Am I doing something wrong here?
Jim
Re: VE & setSize on JPanel class [message #128148 is a reply to message #127966] Mon, 10 July 2006 10:25 Go to previous messageGo to next message
No you are not doing anything wrong, the problem is there is nothing in
your JPanel, so its preferred height is 0 when there is nothing in it.
You put it in the South location, in that location the BorderLayout will
make the width of the control as wide as the parent panel and only as
tall as the preferred height of the panel.
Until you set some controls into it (which you can do by dropping on the
Java Beans Viewer) the panel will not have height.
>>a setSize.
> Jim
Rich Kulp
Re: VE & setSize on JPanel class [message #128200 is a reply to message #128148] Mon, 10 July 2006 10:52 Go to previous messageGo to next message
Rich Kulp wrote, On 7/10/2006 10:25 AM:
> It seems to me that I should be able to drop things onto the panel in the VE
itself. That is the way it is done in other GUIs such as Sun Studio Creator.
Re: VE & setSize on JPanel class [message #128210 is a reply to message #128148] Mon, 10 July 2006 10:55 Go to previous messageGo to next message
And I just went back into my project and reset the preferred size to 0,0, and it
shrunk to a horizontal line, even though it contained components. It would not
accept a blank for the preferred size. So I am confused.
Jim
Re: VE & setSize on JPanel class [message #128222 is a reply to message #128200] Mon, 10 July 2006 11:03 Go to previous message
The VE is showing you exactly what you would see in the real app. Since
it would be 0 height in the real app it is zero height in the VE.
You can drop controls on the Java Beans Viewer. That will put them in
the panel, and now panel will have a height.
Rich Kulp
Re: VE & setSize on JPanel class [message #613459 is a reply to message #127697] Wed, 05 July 2006 19:27 Go to previous message
a setSize.
> Hello,
> My question
> thanks,
> Luis
Rich Kulp
Re: VE & setSize on JPanel class [message #613479 is a reply to message #127710] Fri, 07 July 2006 19:12 Go to previous message
> a setSize.
Jim
Re: VE & setSize on JPanel class [message #613493 is a reply to message #127966] Mon, 10 July 2006 10:25 Go to previous message
>>a setSize.
> Jim
Rich Kulp
Re: VE & setSize on JPanel class [message #613497 is a reply to message #128148] Mon, 10 July 2006 10:52 Go to previous message
Re: VE & setSize on JPanel class [message #613498 is a reply to message #128148] Mon, 10 July 2006 10:55 Go to previous message
Jim
Re: VE & setSize on JPanel class [message #613499 is a reply to message #128200] Mon, 10 July 2006 11:03 Go to previous message
Rich Kulp
Previous Topic:Does the ve support custom data type?
Next Topic:VE 1.3?
Current Time: Fri Sep 19 07:06:48 EDT 2025
Powered by FUDForum. Page generated in 0.05900 seconds
