Home » Eclipse Projects » Sirius » Specifying Save/Load options at runtime
Specifying Save/Load options at runtime [message #1281681] Tue, 01 April 2014 03:46 Go to next message
with Sirius, how can I specify Load/Save options for semantic resources
at runtime? For example say there's a user preference to pretty print
xml or not.
Felix
Re: Specifying Save/Load options at runtime [message #1281745 is a reply to message #1281681] Tue, 01 April 2014 05:41 Go to previous messageGo to next message
Le 01/04/2014 09:46, Felix Dorner a écrit :
Hi.
> xml or not.
For loading, maybe something like this (completely untested):
rs = session.getTransactionalEditingDomain().getResourceSet();
rs.getLoadOptions().put(KEY, VALUE);
session.addSemanticResource(uri, pm);
The actual loading is performed using ResourceSet#getResource(uri,
true), which should honor the default load options set on the resource
set. You may want to revert your customizations afterwards if they can
have side-effects on other resources.
For saving, simply pass the options in the map argument of
Session.save(Map<?,?>, IProgressMonitor).
Re: Specifying Save/Load options at runtime [message #1281751 is a reply to message #1281745] Tue, 01 April 2014 05:51 Go to previous messageGo to next message
I see.
But won't this apply the options to all resources (semantic and
sirius/diagrams?)
Re: Specifying Save/Load options at runtime [message #1281837 is a reply to message #1281751] Tue, 01 April 2014 08:26 Go to previous message
> sirius/diagrams?)
Yes. If you need further control, you can provide your own
implementation of org.eclipse.sirius.business.api.session.SavingPolicy,
and configure the session to use it using Session.setSavingPolicy().
When your policy is called, it gets the options which were passed to
Session.save(), but you can then interpret them as you want, or set
specific ones for some of the resources.
Previous Topic:Multiple model files?
Next Topic:Semantic model based on XML schema generated ecore and handling of DocumentRoot class
Current Time: Sun Jul 20 22:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.25387 seconds
