Home » Eclipse Projects » Remote Application Platform (RAP) » Table right click selection does not set selection
| Table right click selection does not set selection [message #128034] |
Wed, 15 April 2009 11:04  |
Hi all,
I want to upgrade from RAP 1.1.1 to 1.2.0-M6, but it seems that a right
click on a table does not set and highlight the selected row anymore (just
like a left click does). It only opens the pop-up menu if declared.
Moreover it doesn't throw MouseEvent or SelectionEvent...
Is this a bug or a normal behavior ?
Loïc
| Re: Table right click selection does not set selection [message #128155 is a reply to message #128129] |
Thu, 16 April 2009 06:47   |
Here is a snippet with a Tree and a Table.
Right click does not set the selection on Firefox 3.0.8 (RAP 1.2.0-M6 AND
CVS Head)
Windows XP.
It works fine on IE 7...
public class ExampleView extends ViewPart
public void createPartControl(Composite parent)
parent.setLayout(new FillLayout());
Composite comp = new Composite(parent, SWT.NONE);
comp.setLayout(new RowLayout());
Tree tree = new Tree(comp, SWT.BORDER | SWT.H_SCROLL |
SWT.V_SCROLL);
tree.setHeaderVisible(true);
tree.setLinesVisible(true);
TreeColumn column1 = new TreeColumn(tree, SWT.LEFT);
column1.setText("Column 1");
column1.setWidth(200);
TreeColumn column2 = new TreeColumn(tree, SWT.CENTER);
column2.setText("Column 2");
column2.setWidth(200);
TreeColumn column3 = new TreeColumn(tree, SWT.RIGHT);
column3.setText("Column 3");
column3.setWidth(200);
for (int i = 0; i < 4; i++)
TreeItem item = new TreeItem(tree, SWT.NONE);
item.setText(new String[]
{ "item " + i, "abc", "defghi" });
for (int j = 0; j < 4; j++)
TreeItem subItem = new TreeItem(item, SWT.NONE);
subItem.setText(new String[]
{ "subitem " + j, "jklmnop", "qrs" });
for (int k = 0; k < 4; k++)
TreeItem subsubItem = new TreeItem(subItem, SWT.NONE);
subsubItem.setText(new String[]
{ "subsubitem " + k, "tuv", "wxyz" });
Table table = new Table(comp, SWT.NONE);
buildTableContent(table);
public void buildTableContent(Table table)
table.setLinesVisible(true);
table.setHeaderVisible(true);
String[] titles =
{ " ", "C", "!", "Description", "Resource", "In Folder",
"Location",
"Location", "Location" };
for (int i = 0; i < titles.length; i++)
TableColumn column = new TableColumn(table, SWT.NONE);
column.setText(titles[i]);
for (int i = 0; i < 30; i++)
TableItem item = new TableItem(table, SWT.NONE);
item.setText(0, "x");
item.setText(1, "y");
item.setText(2, "!");
item.setText(3, "this stuff behaves the way I expect");
item.setText(4, "almost everywhere");
item.setText(5, "some.folder");
item.setText(6, "line " + i + " in nowhere");
item.setText(7, "line " + i + " in nowhere");
item.setText(8, "line " + i + " in nowhere");
table.getColumn(i).pack();
public void setFocus()
Loïc
Loïc Bertholet wrote:
> Hi Ralf and Ivan,
> I tried with the latest version from CVS Head and I had the same problem.
> I'm on Windows XP and I use Firefox 3.0.3.
> I test it on IE 7 and it works fine so I guess it's a FF problem...
> It seems to be close to bug 264568 expect that i'm on XP instead of Fedora.
> Also, i'm experiencing the same problem with TreeViewer.
> I will try to provide a snippet as soon as possible but I think that it is
> a environment problem...
> Loïc
| Re: Table right click selection does not set selection [message #128236 is a reply to message #128155] |
Thu, 16 April 2009 10:37  |
Hi Loïc,
I can't reproduce it with your snippet on both Windows XP SP3 and Vista
SP1 with FF 3.0.8. Both Tree and Table items are selected on right mouse
click. It seems that you are right - it is environment dependent issue.
Best,
Ivan
> AND CVS Head)
> Windows XP.
> SWT.V_SCROLL);
> String[] titles =
> "Location",
> Regards,
> Loïc
>> Hi Ralf and Ivan,
>> problem.
>> Fedora.
>> it is a environment problem...
>> Thanks,
>> Loïc
Current Time: Sun Nov 02 20:59:14 EST 2025
Powered by FUDForum. Page generated in 0.25736 seconds
