Home » Eclipse Projects » DTP » JAR Location
JAR Location [message #11723] Tue, 02 May 2006 04:21 Go to next message
Originally posted by: reply-to-group.zend.com
I am trying to figure out if there is a way to change the default Jar paths
that were hard coded into the plug-in xml as part of the
org.eclipse.datatools.connectivity.driverExtension template nodes.
As it appears, the jarList property is hard coded into the plug-in and I
could not find a way where I can re-define it from another plug-in.
The idea is to create a plug-in that will contain a Jar for derby (for
example) and then I will override the jarList with the valid Jar path.
Is this possible?
-- Shalom
Re: JAR Location [message #12472 is a reply to message #11723] Thu, 04 May 2006 03:50 Go to previous messageGo to next message
Anyone?
> Hi
> paths that were hard coded into the plug-in xml as part of the
> Is this possible?
> Thanks
> -- Shalom
Re: JAR Location [message #12583 is a reply to message #11723] Thu, 04 May 2006 18:27 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Shalom!
At this point you cannot override the driver template from another plug-in.
You would be able to create your own driver that included a reference to the
jar.
If you feel the ability to override a driver entry would be a good one, you
can create an enhancement request for DTP Connectivity to do so. If you do
that, would you mind providing a detailed use case for discussion?
Thanks!
--Brian Fitzpatrick (DTP-Connectivity Committer)
"Shalom Gibly" <reply-to-group@zend.com> wrote in message
news:e374qt$rrq$1@utils.eclipse.org...
> Hi
paths
> Is this possible?
> Thanks
> -- Shalom
Re: JAR Location [message #12795 is a reply to message #12583] Sun, 07 May 2006 04:12 Go to previous message
Just created such request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=140493
-- Shalom
"Brian Fitzpatrick" <brianf@sybase.com> wrote in message
news:e3dv3m$sjv$1@utils.eclipse.org...
> Hi Shalom!
> plug-in.
> the
> jar.
> you
> Thanks!
>> Hi
> paths
>> Is this possible?
>> Thanks
>> -- Shalom
Re: JAR Location [message #573500 is a reply to message #11723] Thu, 04 May 2006 03:50 Go to previous message
Anyone?
> Hi
> Is this possible?
> Thanks
> -- Shalom
Re: JAR Location [message #573663 is a reply to message #11723] Thu, 04 May 2006 18:27 Go to previous message
Hi Shalom!
jar.
Thanks!
> Hi
paths
> Is this possible?
> Thanks
> -- Shalom
Re: JAR Location [message #574042 is a reply to message #12583] Sun, 07 May 2006 04:12 Go to previous message
-- Shalom
> Hi Shalom!
> plug-in.
> the
> jar.
> you
> Thanks!
>> Hi
> paths
>> Is this possible?
>> Thanks
>> -- Shalom
Previous Topic:Command line SQL executioner
Next Topic:Relative path for JAR location
Current Time: Fri Jul 18 23:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.04888 seconds
