Home » Eclipse Projects » NatTable » NatTable : Table level validations(How to validate all the rows in a NatTable grid upon a button click.)
NatTable : Table level validations [message #1278693] Thu, 27 March 2014 14:16 Go to next message
I need to implement some table level validations for a NatTable grid. I am able to validate individual cells using "org.eclipse.nebula.widgets.nattable.data.validate.DataValidator" and I could do it only for text boxes using TextCellEditor (I could also highlight the cells by setting errorDecorationText for the text boxes which have validation errors).
Similarly, I need to validate certain combo boxes (drop down boxes) in a NatTable grid but not at a Cell level but at a table level. (like upon a button click, where there exists a button underneath a NatTable grid), Also, I need to highlight the combo box cells which have validation errors. Can somebody post any suggestions ?
Please let me know if you need more information.
Pavan Kalyan.
Re: NatTable : Table level validations [message #1278808 is a reply to message #1278693] Thu, 27 March 2014 18:01 Go to previous messageGo to next message
Hi Pavan,
You need to attach a label to the cells that have validation errors, and then register a Style (perhaps with a background color or red/pink) under that same label.
Here's how you register the style:
public static final String CELL_ERROR = "invalid";
configRegistry.registerConfigAttribute(
			CellConfigAttributes.CELL_STYLE,
			style,
			DisplayMode.NORMAL,
			CELL_ERROR);
You might also want to have a label accumulator, which will add the CELL_ERROR label to the cells that have an error.
Here's how you might do that:
natTableBodyDataLayer.setConfigLabelAccumulator(new IConfigLabelAccumulator() {
            public void accumulateConfigLabels(LabelStack configLabels,
                    int columnPosition, int rowPosition) {
                    if (errorExistsOnCell (columnPosition, rowPosition)) {
			configLabels.addLabelOnTop(CELL_ERROR);
Cheers!
Re: NatTable : Table level validations [message #1279062 is a reply to message #1278808] Fri, 28 March 2014 03:32 Go to previous messageGo to next message
the above explanation is correct. What you need is some kind of weak validation, as hard validation will not allow to commit a value to the data model.
I wrote a blog post about this a while ago: http://blog.vogella.com/2013/03/02/crossweak-validation-in-nattable-by-dirk-fauth/
Greez,
Dirk
Re: NatTable : Table level validations [message #1464263 is a reply to message #1279062] Fri, 07 November 2014 06:08 Go to previous messageGo to next message
I am able to use the validation on the cell.
I am using it in the way it is being used in the cross validation example by you.
class EventDataValidator extends DataValidator {
private IRowDataProvider bodyDataProvider;
EventDataValidator(IRowDataProvider bodyDataProvider) {
this.bodyDataProvider = bodyDataProvider;
public boolean validate(int columnIndex, int rowIndex, Object newValue) {
Here the problem I am facing is on clicking enter after the cell value is entered, the error message is not invoked immediately.
When I start entering the value in the new cell it gets invoked .
Can you please help
Re: NatTable : Table level validations [message #1464298 is a reply to message #1464263] Fri, 07 November 2014 06:58 Go to previous message
Have a look at _4451_CrossValidationGridExample in the NatTable example application. Maybe there is some mistake in the blog post that has been fixed there
Previous Topic:NatTable Auto Focus functionality
Next Topic:Minimum number of rows visible
Current Time: Sun Jul 27 02:27:31 EDT 2025
Powered by FUDForum. Page generated in 0.04289 seconds
