Home » Archived » Jubula » Newbie - Observation Console doesn't open in Observation Mode
Newbie - Observation Console doesn't open in Observation Mode [message #1276209] Mon, 24 March 2014 04:34 Go to next message
Hi everyone,
I just started to do some tutorials for using Jubula and after connecting to AUT I wanted to start the Obervation Mode. After creating a new Test Case it is said that a Obervation Console should open. It doesn't... Does anyone know why?
Thank you very much in advance!
Re: Newbie - Observation Console doesn't open in Observation Mode [message #1277575 is a reply to message #1276209] Wed, 26 March 2014 02:58 Go to previous messageGo to next message
Hi Viet,
It sounds like you've missed some steps - check in the documentation for the steps to begin observing.
I'd also highly recommend doing the cheat sheets (available via the help menu). They'll show you how to create a test case using the library of unbound modules.
Alex
Re: Newbie - Observation Console doesn't open in Observation Mode [message #1277598 is a reply to message #1277575] Wed, 26 March 2014 03:47 Go to previous messageGo to next message
Hi Alex,
thank you for your reply!
I checked and rechecked all the steps and I can't find the step I missed. It works with Java swt application. Already did some little tests. I also could map in the swt application but the rcp? Mapping and Observing doesn't work. Could it be something with the AUT connection?
Viet-Ha
Re: Newbie - Observation Console doesn't open in Observation Mode [message #1278667 is a reply to message #1277598] Thu, 27 March 2014 13:18 Go to previous message
Hi Viet,
Based on your description it sounds like the RCP-Accessor isn't correctly running. Check out the section in the user manual on setting up an RCP application for testing - it's in the chapter on "Toolkit information".
Another question - when you start the AUT, does it have e.g. a workspace chooser (if so, you have to choose the workspace as a part of the AUT configuration using -data), and can you see the AUT in the running AUTs view once it is started?
Alex
Previous Topic:Custom methods in Jubula
Next Topic:Does each external command happen in its own terminal?
Current Time: Sat Jul 26 02:38:42 EDT 2025
Powered by FUDForum. Page generated in 0.06528 seconds
