Home » General (non-technical) » Project Proposals » New project proposal: Lightweight M2M (liblwm2m)
New project proposal: Lightweight M2M (liblwm2m) [message #1220802] Fri, 13 December 2013 12:24 Go to next message
Despite its name, liblwm2m is not a library but files to be built with an application. It is written in C and designed to be portable on POSIX compliant systems.
Two compilation switches are used: LWM2M_CLIENT_MODE and LWM2M_SERVER_MODE. Defining LWM2M_CLIENT_MODE enables the LWM2M Client interfaces. Defining LWM2M_SERVER_MODE enables the LWM2M Server interfaces. Both can be defined at the same time.
http://www.eclipse.org/proposals/technology.liblwm2m
Re: New project proposal: Lightweight M2M (liblwm2m) [message #1224805 is a reply to message #1220802] Fri, 27 December 2013 15:52 Go to previous messageGo to next message
I heard by ARM's EC rep who seems to participate in the WG for this at OMA
about Lightweight M2M and did a review of the current "Candidate Spec"
(see http://technical.openmobilealliance.org/Technical/current_releases.aspx
despite its "1.0" number it is no more than an Eclipse project "incubating"
or a non-final JSR in the Java Community Process;-)
Unfortunately there are still many things either undefined, vaguely defined
or insufficient, just taking a fuzzy "time interval in seconds" as an
example, where Real Time M2M expecially if you have a C system use millis or
even nanosecond precision. That and other things not yet formulated make OMA
Lightweight M2M immature and a project should not rely on something still
incomplete.
There are overlaps, especially with the Californium project, though most of
them use Java or JavaScript.
I'd wait wit this till the standard is mature and accepted, rather than a
Candidate Spec.
Werner
"Wayne Beaton" schrieb im Newsbeitrag news:l8ffrq$15i$1@xxxxxxxxe.org...
compliant systems.
at the same time.
Diese E-Mail ist frei von Viren und Malware, denn der avast! Antivirus Schutz ist aktiv.
http://www.avast.com
Re: New project proposal: Lightweight M2M (liblwm2m) [message #1228561 is a reply to message #1220802] Tue, 07 January 2014 09:00 Go to previous messageGo to next message
I'm an interested party, on behalf of my company, 1248.
Having a working reference implementation of LWM2M including DTLS and bootstrap would be very useful to us.
Re: New project proposal: Lightweight M2M (liblwm2m) [message #1277810 is a reply to message #1228561] Wed, 26 March 2014 09:54 Go to previous message
I declare the project creation successful. Project provisioning will start shortly.
Previous Topic:New project proposal: Flight
Next Topic:New Project Proposal: Mobile Map Tools
Current Time: Sat Jul 26 08:48:01 EDT 2025
Powered by FUDForum. Page generated in 0.09649 seconds
