Home » Eclipse Projects » Equinox » manifest.mf file
manifest.mf file [message #127612] Mon, 16 March 2009 03:25 Go to next message
Originally posted by: egidijus.vaisnora.nomagiclt.com
Does manifest.mf support relative paths "Bundle-ClassPath"?
Problem appeared when I have moved runtime information (relative paths to libraries) from the plugin.xml to the manifest.mf
file into "Bundle-ClassPath". The result is strange - there are no exception (-debug option was used), plugin is shown in
plug-in list, but there are no UI item of this plugin!
Another question: Does "Export-Package" support patterns like "*"? In help it is not mentioned, but Eclipse doesn't complains
if I use such pattern...
Please advice
Thank you!
Egidijus
Re: manifest.mf file [message #127747 is a reply to message #127612] Thu, 19 March 2009 06:58 Go to previous messageGo to next message
I ment relative path something like:
Bundle-ClassPath: ../../../../../lib/x.jar,
../../../../../lib/y.jar,
plugin_eclipse_api.jar,
../../../../../lib/z.jar,
> to libraries) from the plugin.xml to the manifest.mf file into
> (-debug option was used), plugin is shown in plug-in list, but there are
> help it is not mentioned, but Eclipse doesn't complains if I use such
> pattern...
> Please advice
> Thank you!
> Egidijus
Re: manifest.mf file [message #127771 is a reply to message #127747] Thu, 19 March 2009 11:23 Go to previous message
The OSGi spec may be useful to you.
http://www.osgi.org/Specifications/HomePage
For Bundle-Classpath, section 3.8.1.
For Export-Package, section 3.5.5.
>> pattern...
>> Please advice
>> Thank you!
>> Egidijus
Previous Topic:org.eclipse.test with dependency on org.eclipse.ui
Next Topic:Running Several Equinox instances within a single JVM
Current Time: Sat Nov 08 17:08:24 EST 2025
Powered by FUDForum. Page generated in 0.03888 seconds
