Home » Language IDEs » Java Development Tools (JDT) » Can't change Eclipse JVM on Mac
Can't change Eclipse JVM on Mac [message #1276963] Tue, 25 March 2014 05:21 Go to next message
I am trying to make Eclipse run under JVM 1.7 rather than 1.6
I have installed a JDK to /Library/Java/JavaVirtualMachines/jdk1.7.0_51.jdk
Then updated Info.plist:
<string>-vm</string><string>/System/Library/Frameworks/JavaVM.framework/Versions/A/Commands/java</string>
(the latter appears to be 1.7.0_51)
But eclipse "About Eclipse/Installation Details/Configuration" still shows that:
-vm /System/Library/Frameworks/JavaVM.framework
java.home=/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home
java.runtime.version=1.6.0_65-b14-462-11M4609
java.version=1.6.0_65
How can I make eclipse run with JVM 1.7?
[Updated on: Tue, 25 March 2014 05:22] by Moderator
Re: Can't change Eclipse JVM on Mac [message #1277184 is a reply to message #1276963] Tue, 25 March 2014 12:16 Go to previous messageGo to next message
You should update Eclipse.app/Contents/MacOS/eclipse.ini and point it
use -vm .... before -vmargs!
Tom
> shows that:
> How can I make eclipse run with JDK 1.7?
Re: Can't change Eclipse JVM on Mac [message #1277213 is a reply to message #1277184] Tue, 25 March 2014 13:18 Go to previous messageGo to next message
I have added
-vm
to eclipse.ini rigth before "-vmargs".
But eclipse still runs under JVM 1.6 rather than 1.7.
Re: Can't change Eclipse JVM on Mac [message #1277662 is a reply to message #1277213] Wed, 26 March 2014 05:39 Go to previous messageGo to next message
Does that really point to Java7? Jdk7 & 8 are installed in
Tom
On 25.03.14 18:18, Missing name Mising name wrote:
> I have added
> -vm
Re: Can't change Eclipse JVM on Mac [message #1277688 is a reply to message #1277662] Wed, 26 March 2014 06:16 Go to previous message
Hm I can somehow remember this -vm not getting picked up appropriately
in the ini file.
Can you try Eclipse.app/Contents/MacOS/eclipse -vm .... to lauch on the
command line.
Tom
> Tom
>> I have added
>> -vm
Previous Topic:Eclipse Kepler JDK issues.
Next Topic:How to setup WAS in Eclipse
Current Time: Tue Nov 04 22:56:29 EST 2025
Powered by FUDForum. Page generated in 0.03980 seconds
