[SOLVED] xText Version running on Eclipse 3.6? [message #1277056] |
Tue, 25 March 2014 08:29  |
I created a little PoC using xText 2.5.3 which I would like to introduce to my current project now.
Since on the projects we are kind of stuck with Eclipse 3.6, because of using IBM Rationals Software Architect 8.0.4, I would like to know which version of xText I have to use in order to run the DSL-UI-Plugin on that distribution?
I know I can create a separate Modelling-Distribution-product but I need to provide it in our main IDE (RSA) in order to comply to project standards.
[Updated on: Tue, 25 March 2014 11:13] by Moderator
Re: xText Version running on Eclipse 3.6? [message #1277204 is a reply to message #1277180] |
Tue, 25 March 2014 13:04  |
EMF itself is compatible with Eclipse 3.6, but it might be the case that
there are tools (bundle) with strict ranges on EMF that exclude higher
versions of EMF even if EMF itself installs and works nicely with
Eclipse 3.6. I think UML2's extended GenModel has such strict ranges
on EMF's GenModel bundles.
On 25/03/2014 9:10 AM, Marc Schlegel wrote:
> Felix Dorner wrote on Tue, 25 March 2014 11:42
>> On 25/03/2014 16:12, Marc Schlegel wrote:
>> > Great. Thanks for the clarification.
>> Make sure you are actually allowed to upgrade EMF too. I'm in a quite
>> similar situation where I can't go beyond EMF 2.8, and thus not able
>> to use the latest XText.
> This could really be a blocker since RSA ships with a lot of Modelling
> Tools (UML) which I bet are based on GEF and thus EMF.
FUDForum. Page generated in 1.05516 seconds
