Home » Newcomers » Newcomers » Installation Instructions
Installation Instructions [message #127711] Thu, 05 January 2006 10:29 Go to next message
Originally posted by: thompson.sparta.com
It seems pretty fundamental, but I have been unable to find installation
instructions for Eclipse. I've downloaded the zip file for a windows
system and since it does not come with an installer, apparently I need to
copy it somewhere. I haven't been able to find anything that tells me
where it likes to live on my system.
Thanks in advance!
Re: Installation Instructions [message #127725 is a reply to message #127711] Thu, 05 January 2006 10:41 Go to previous messageGo to next message
Originally posted by: osadeh.gmail.com
Simple extract it somewhere!
Also, make sure you have a valid JRE installed.
HTH,
Oren
> to copy it somewhere. I haven't been able to find anything that tells
> me where it likes to live on my system.
> Thanks in advance!
Re: Installation Instructions [message #127760 is a reply to message #127711] Thu, 05 January 2006 11:03 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Extract the zip file somewhere you're comfortable with (on Windows, I
usually put it in C:\Program Files) and in the extracted files there is
a 'readme' folder that contains a file called readme_eclipse.html.
Section 4 is called "running eclipse" and contains info that could be
useful to you.
You can also go for broke and double-click the 'eclipse' executable file
in the unzipped directory; that should work if you have a Java JRE
installed.
D.
> Thanks in advance!
Re: Installation Instructions [message #127860 is a reply to message #127760] Thu, 05 January 2006 16:12 Go to previous messageGo to next message
Originally posted by: kimberly.koran.ed.gov
I am new, obviously! When I attempt to launch Eclipse in Windows 2000 with
JRE 1.5 I get:
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Any ideas?
Re: Installation Instructions [message #127898 is a reply to message #127860] Thu, 05 January 2006 18:31 Go to previous messageGo to next message
Originally posted by: nobody.there.127.0.0.1
> with JRE 1.5 I get:
> !STACK
It looks like this has been seen before, but isn't common:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=84678
I'd suggest two things:
1. Start in a shell that has minimal environment variables defined (no
JAVA_HOME, for instance) and see if that works.
2. If that doesn't, follow the procedure in the defect report. Update
the defect report and give the Eclipse team the info they say they're
looking for.
Andrew Jr.
IBM Phoenix Labs (OTI)
2929 North Central Avenue
Phoenix, Arizona, USA 85012
Re: Installation Instructions [message #128136 is a reply to message #127898] Fri, 06 January 2006 17:39 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Andrew Cornwall wrote:
>> with JRE 1.5 I get:
>> !STACK
This is most often caused by unzipping Eclipse without specifying that
the ZIP directory structure should be maintained. Apparently, some ZIP
tools (WinZip) don't make this the default option and a lot of people
end up unzipping the entire structure to a single flat directory.
When Eclipse is unzipped, it should have an entire tree of
subdirectories such as plugins, features, configuration, etc.
HTH,
Eric
Re: Installation Instructions [message #128345 is a reply to message #127760] Sun, 08 January 2006 15:13 Go to previous messageGo to next message
Originally posted by: nospam.for.me
How is an uninstall done?
There is nothing in "readme_eclipse.html" on how to remove eclipse.
"Eclipse WebMaster (Denis Roy)" <webmaster@eclipse.org> wrote in message
news:dpjg1q$s01$1@utils.eclipse.org...
> usually put it in C:\Program Files) and in the extracted files there is a
> 'readme' folder that contains a file called readme_eclipse.html. Section 4
> is called "running eclipse" and contains info that could be useful to you.
> installed.
> D.
>> Thanks in advance!
Re: Installation Instructions [message #128492 is a reply to message #128345] Mon, 09 January 2006 11:21 Go to previous messageGo to next message
Simply delete the 'eclipse' directory that got added during the install.
Dani
>>installed.
>>D.
>>>Thanks in advance!
Re: Installation Instructions [message #129187 is a reply to message #128492] Wed, 11 January 2006 13:59 Go to previous messageGo to next message
And what happens with your old settings? I suppose they are stored in a
safe place, but who knows? Also, is there a problem installing over the
old directory or should I uninstall/delete it first?
I'm really flabbergasted that a project like eclipse doesn't have this
basic information. Look at firefox to see a project with good instructions.
Thanks for reading, Roland
Re: Installation Instructions [message #129207 is a reply to message #129187] Wed, 11 January 2006 14:15 Go to previous messageGo to next message
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <dq3kim$h5v$1@utils.eclipse.org>,
please@reply.to.the.newsgroup says...
Your settings are stored in your workspace. Don't install over a
previous installation; delete the old one first.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Installation Instructions [message #129809 is a reply to message #128136] Mon, 16 January 2006 01:36 Go to previous message
Originally posted by: richhart.cox.net
I got the exact same error message (could not find bootstrap code). What
fixed it, as suggested, was in fact unzipping the files making sure the
option to use the archived folder structure was selected.
I am very grateful for the information here in this Newsgroup!
Previous Topic:adding tld to a java project
Next Topic:Error opening .JAVA file created in different tool
Current Time: Fri Nov 07 22:38:21 EST 2025
Powered by FUDForum. Page generated in 0.09876 seconds
