Home » Modeling » TMF (Xtext) » [SOLVED] xText Version running on Eclipse 3.6?
[SOLVED] xText Version running on Eclipse 3.6? [message #1277056] Tue, 25 March 2014 08:29 Go to next message
I created a little PoC using xText 2.5.3 which I would like to introduce to my current project now.
Since on the projects we are kind of stuck with Eclipse 3.6, because of using IBM Rationals Software Architect 8.0.4, I would like to know which version of xText I have to use in order to run the DSL-UI-Plugin on that distribution?
I know I can create a separate Modelling-Distribution-product but I need to provide it in our main IDE (RSA) in order to comply to project standards.
[Updated on: Tue, 25 March 2014 11:13] by Moderator
Re: xText Version running on Eclipse 3.6? [message #1277120 is a reply to message #1277056] Tue, 25 March 2014 10:26 Go to previous messageGo to next message
Marc,
I believe that the latest release of Xtext should work with Eclipsed 3.6.
> standards.
> Thanks
Re: xText Version running on Eclipse 3.6? [message #1277132 is a reply to message #1277120] Tue, 25 March 2014 10:45 Go to previous messageGo to next message
That would be great. My concerns are based on dependency injection in Eclipse which was introduced post 3.6 as far as I remember. xText uses Guice for all its wiring and hence I thought this wont work.
Btw: Ed, thanks for your great work on EMF which is the foundation of so many great tools today Smile
Re: xText Version running on Eclipse 3.6? [message #1277139 is a reply to message #1277132] Tue, 25 March 2014 10:55 Go to previous messageGo to next message
Xtexts DI has nothing todo with Eclipse 4 DI
Re: xText Version running on Eclipse 3.6? [message #1277140 is a reply to message #1277132] Tue, 25 March 2014 10:55 Go to previous messageGo to next message
Re: xText Version running on Eclipse 3.6? [message #1277147 is a reply to message #1277139] Tue, 25 March 2014 11:12 Go to previous messageGo to next message
Great. Thanks for the clarification.
Re: xText Version running on Eclipse 3.6? [message #1277165 is a reply to message #1277147] Tue, 25 March 2014 11:42 Go to previous messageGo to next message
Make sure you are actually allowed to upgrade EMF too. I'm in a quite
similar situation where I can't go beyond EMF 2.8, and thus not able to
use the latest XText.
Re: xText Version running on Eclipse 3.6? [message #1277180 is a reply to message #1277165] Tue, 25 March 2014 12:10 Go to previous messageGo to next message
Felix Dorner wrote on Tue, 25 March 2014 11:42
RSA ships with a lot of Modelling Tools (UML) which I bet are based on GEF and thus EMF. I will update this post about my success or failure Smile
[Updated on: Tue, 25 March 2014 12:11] by Moderator
Re: xText Version running on Eclipse 3.6? [message #1277204 is a reply to message #1277180] Tue, 25 March 2014 13:04 Go to previous message
EMF itself is compatible with Eclipse 3.6, but it might be the case that
there are tools (bundle) with strict ranges on EMF that exclude higher
versions of EMF even if EMF itself installs and works nicely with
Eclipse 3.6. I think UML2's extended GenModel has such strict ranges
on EMF's GenModel bundles.
>> to use the latest XText.
> This could really be a blocker since RSA ships with a lot of Modelling
Previous Topic:Customizing ScopeProvider for cross references using JvmReferenceType (XBase)
Next Topic:Strange behavior of XText
Current Time: Fri Jul 25 23:40:54 EDT 2025
Powered by FUDForum. Page generated in 0.06573 seconds
