Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller is unavailable . . .
Agent Controller is unavailable . . . [message #127594] Sun, 30 March 2008 18:43 Go to next message
Originally posted by: jaguar0616.gmail.com
This is under Eclipse 3.3.2 and TPTP Platform 4.4.1 & TPTP Tracing and
Profiling Tools v. 4.3.1 with Sun's Java v. 1.5 . . .
Under Ubuntu and profiling a local application I'm getting the errors:
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10002 . . .
and
at org.eclipse.tptp.platform.iac.administrator.internal.startst op.
AutoStartStop.hasProcessTerminated(AutoStartStop.java:275) . . .
Since there's no configuration with the IAC, where do I go from here?
Thank you!
Re: Agent Controller is unavailable . . . [message #127606 is a reply to message #127594] Mon, 31 March 2008 01:43 Go to previous messageGo to next message
Originally posted by: ck2329.mail.ru
I think that you are running wrong configuration.
Please refer to
http://www.eclipse.org/newsportal/article.php?id=5956&gr oup=eclipse.tptp#5956
thread - this may resolve your issue
Re: Agent Controller is unavailable . . . [message #127619 is a reply to message #127606] Mon, 31 March 2008 03:06 Go to previous messageGo to next message
Well, in the Profile Dialog, in Attach to Agent, I get a pop-up error:
"An internal error occurred during: Fetching children of host"
and there are no agents listed under the Agents tab.
So . . . ????
Re: Agent Controller is unavailable . . . [message #127642 is a reply to message #127619] Mon, 31 March 2008 06:47 Go to previous messageGo to next message
Have you read link i gave you ?
If you choose Attach to agent - that means that you must already start
standalone Agent Controller (not IAC) and profiling or other agent.
If you want to use IAC - then you must choose profile application.
Re: Agent Controller is unavailable . . . [message #127667 is a reply to message #127594] Tue, 01 April 2008 03:18 Go to previous messageGo to next message
Ubuntu is a bit incompatible with TPTP Agent Controller's startup scripts.
ACStart.sh script uses /bin/sh and bash is implied.
Ubuntu has other default shell (dash?). You can or modify ACStart.sh to
use bash or map /usr/sh to bash.
Igor
Re: Agent Controller is unavailable . . . [message #127680 is a reply to message #127619] Tue, 01 April 2008 03:25 Go to previous messageGo to next message
This IAC's defect ("Fetching children..") is tracked under the
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224471.
As a workaround you can startup IAC before profiling
(Window/Preferences/Agent Controller/Hosts/"Test Connection" menu item) or
use standalone AC as well.
Re: Agent Controller is unavailable . . . [message #127690 is a reply to message #127642] Tue, 01 April 2008 03:31 Go to previous message
Can't agree :)
Of course IAC also can be used in attaching scenario.
You just need to startup it before with "Test Connection" or any another
activity. IAC wiil be launched automatically.
Previous Topic:Monitoring without network access
Next Topic:Profiling a web application with wtp
Current Time: Sat Jul 26 03:10:57 EDT 2025
Powered by FUDForum. Page generated in 0.24732 seconds
