Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] How to deactivate
[EMF Compare] How to deactivate [message #127564] Fri, 25 July 2008 15:06 Go to next message
Originally posted by: lwrage.sei.cmu.edu
I've installed eclipse-modeling-ganymede-incubation-win32.zip, which
includes EMF compare. How can I turn it off to compare a uml file with
the version on cvs using plain text comparison?
(The 600KB file seems to be too big for EMF compare, it takes more than
five minutes to open the compare editor.)
Lutz
Re: [EMF Compare] How to deactivate [message #127590 is a reply to message #127564] Sat, 26 July 2008 17:07 Go to previous messageGo to next message
--------------070709070608050504070308
Hi Lutz,
org.eclipse.compare doesn't provide a way to choose the comparison
engine to use among those registered. However you should still be able
to force text comparison :
http://wiki.eclipse.org/EMF_Compare_FAQ#How_to_force_text_co mparison.3F
Laurent Goubet Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #127603 is a reply to message #127590] Sun, 27 July 2008 07:58 Go to previous messageGo to next message
Thanks!
- Lutz
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:g6g3mq$se0$2@build.eclipse.org...
> Hi Lutz,
> Regards,
> Laurent Goubet Obeo
> Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #127614 is a reply to message #127603] Sun, 27 July 2008 13:58 Go to previous messageGo to next message
I tried it, but it does not work. Even after restarting eclipse, uml files
don't use text compare.
Preferences->Content Types->EMF Compare
*.ecore (locked)
*.emfdiff (locked)
*.uml (locked)
Preferences->Content Types->Text
*.uml
*.txt (locked)
I played a bit with the *.compare.ui plugin.xml and got rid of the locked
uml entry, but that didn't help either.
- Lutz
"Lutz Wrage" <lwrage@sei.cmu.edu> wrote in message
news:g6hns0$shl$1@build.eclipse.org...
> Thanks!
> - Lutz
>> Hi Lutz,
>> Regards,
>> Laurent Goubet Obeo
>> Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #127627 is a reply to message #127614] Mon, 28 July 2008 03:54 Go to previous messageGo to next message
--------------020607060608090901070805
Hi Lutz,
I tested this in 3.3 and it still seems to work; was your behavior
observed on ganymede?
Either way, could you fill in a bugzilla entry so that we know we have
to provide a way to force a textual comparison (we could probably do it
by means of a preference or the such)?
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #127638 is a reply to message #127627] Mon, 28 July 2008 08:06 Go to previous messageGo to next message
The problem is on ganymede:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242219
- Lutz
laurent Goubet wrote, on 7/28/2008 3:54 AM:
> Hi Lutz,
> Thanks
> Laurent Goubet
> Obeo
>> files don't use text compare.
>> *.ecore (locked)
>> *.emfdiff (locked)
>> *.uml (locked)
>> *.uml
>> *.txt (locked)
>> locked uml entry, but that didn't help either.
>> - Lutz
>>> Thanks!
>>> - Lutz
>>>> Hi Lutz,
>>>> Regards,
>>>> Laurent Goubet Obeo
>>>>> Hi,
>>>>> than
>>>>> Thanks,
>>>>> Lutz
Re: [EMF Compare] How to deactivate [message #127651 is a reply to message #127638] Mon, 28 July 2008 11:07 Go to previous messageGo to next message
--------------040102030000040900080004
Thanks Lutz.
As a side note, we're currently trying to pinpoint performances issues
we have on some configurations with the opening of the compare editor.
You told that it takes more than five minutes to "open the compare
editor". Could you be more precise as to what takes that much time? Is
it the comparison itself (with the progress monitor showing) or the
opening of the editor after the progress monitor closes up?
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #127714 is a reply to message #127651] Wed, 30 July 2008 04:06 Go to previous message
--------------050901050907010206000403
Thanks to Lutz input, the most important bottleneck has been eliminated
and UI performances should now be way better than they were. We're still
working on some flickering issues appearing on windows, but this should
be fixed soon.
Laurent Goubet
Obeo
laurent Goubet a
Re: [EMF Compare] How to deactivate [message #620151 is a reply to message #127564] Sat, 26 July 2008 17:07 Go to previous message
Hi Lutz,
Laurent Goubet Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620152 is a reply to message #127590] Sun, 27 July 2008 07:58 Go to previous message
Thanks!
- Lutz
> Hi Lutz,
> Regards,
> Laurent Goubet Obeo
> Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620153 is a reply to message #127603] Sun, 27 July 2008 13:58 Go to previous message
*.ecore (locked)
*.emfdiff (locked)
*.uml (locked)
*.uml
*.txt (locked)
- Lutz
> Thanks!
> - Lutz
>> Hi Lutz,
>> Regards,
>> Laurent Goubet Obeo
>> Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620154 is a reply to message #127614] Mon, 28 July 2008 03:54 Go to previous message
Hi Lutz,
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620155 is a reply to message #127627] Mon, 28 July 2008 08:06 Go to previous message
- Lutz
> Hi Lutz,
> Thanks
> Laurent Goubet
> Obeo
>> *.ecore (locked)
>> *.emfdiff (locked)
>> *.uml (locked)
>> *.uml
>> *.txt (locked)
>> - Lutz
>>> Thanks!
>>> - Lutz
>>>> Hi Lutz,
>>>> Regards,
>>>> Laurent Goubet Obeo
>>>>> Hi,
>>>>> than
>>>>> Thanks,
>>>>> Lutz
Re: [EMF Compare] How to deactivate [message #620156 is a reply to message #127638] Mon, 28 July 2008 11:07 Go to previous message
Thanks Lutz.
Laurent Goubet
Obeo
Lutz Wrage a
Re: [EMF Compare] How to deactivate [message #620161 is a reply to message #127651] Wed, 30 July 2008 04:06 Go to previous message
be fixed soon.
Laurent Goubet
Obeo
laurent Goubet a
Previous Topic:Teneo and Hibernate's Session.load() issue
Next Topic:Teneo and Hibernate's Session.load() issue
Current Time: Fri Jul 18 15:51:34 EDT 2025
Powered by FUDForum. Page generated in 0.12528 seconds
