Home » Modeling » Epsilon » [EGL] Append output to existing file
[EGL] Append output to existing file [message #1272615] Tue, 18 March 2014 06:39 Go to next message
I would like to run the same M2T transformation several times, with different inputs, and append the output to the same file.
Here is an example snippet from an EGL file:
	var f = new Native("org.eclipse.epsilon.egl.formatter.language.JavaFormatter");
	TemplateFactory.setDefaultFormatter(f);
	for(binding in Binding.all) {
		var template:Template = TemplateFactory.load("binding.egl");
		template.populate("binding",binding);
		template.generate("generated/out.txt");
The out.txt file will be overwritten each time, is there an option to only append to file?
I considered using
template.process()
to get a string of the generated content and append to it, but could not find a way to write it to a file.
thanks for your help,
Esteban
Re: [EGL] Append output to existing file [message #1272857 is a reply to message #1272615] Tue, 18 March 2014 19:56 Go to previous messageGo to next message
Hi Esteban,
Instead of template.generate() you should be able to invoke template.append().
Dimitris
Re: [EGL] Append output to existing file [message #1273161 is a reply to message #1272857] Wed, 19 March 2014 12:25 Go to previous messageGo to next message
using this code:
		template.append("generated/out.txt");
I get this error:
Method 'append' not found for: org.eclipse.epsilon.egl.EglFileGeneratingTemplate
I checked the javadoc here: http://download.eclipse.org/epsilon/javadoc/ and could not find this method.
I have everything from the interim update site (http://download.eclipse.org/epsilon/interim/) installed.
Esteban
Re: [EGL] Append output to existing file [message #1273186 is a reply to message #1273161] Wed, 19 March 2014 13:30 Go to previous messageGo to next message
Hi Esteban,
You're right - this hasn't made it to the interim update site yet. I plan to release a new interim version over the weekend but please let me know if this is a blocker and I'll try to do this sooner.
Dimitris
Re: [EGL] Append output to existing file [message #1274508 is a reply to message #1273186] Fri, 21 March 2014 11:20 Go to previous messageGo to next message
there is no rush, I can wait Smile
Esteban
Re: [EGL] Append output to existing file [message #1282380 is a reply to message #1274508] Wed, 02 April 2014 03:59 Go to previous message
Hi Esteban,
This should now be available in the latest interim release.
Dimitris
Previous Topic:Add plugin dep to diagram generated code!
Next Topic:Collection Type Specification
Current Time: Sat Jul 26 12:08:06 EDT 2025
Powered by FUDForum. Page generated in 0.35550 seconds
