Solved How to extend xbase::XBlockExpression? [message #1278384 is a reply to message #1278322] |
Thu, 27 March 2014 05:00   |
I do not know if this is the best solution but now it works. Maybe it will help others.
I changed the copiler to
class MyDslCompiler extends XbaseCompiler {
@Inject extension JvmTypesBuilder
override protected doInternalToJavaStatement (XExpression expr, ITreeAppendable it, boolean isReferenced) {
switch (expr)
MyBlockExpression:
val greeting = EcoreUtil2::getContainerOfType(expr, Greeting)
if (greeting != null)
newLine.append('''final String MN = "«greeting.name»";''')
newLine.append('''System.out.println("entering <«greeting.name»>");''')
super.doInternalToJavaStatement(expr as XBlockExpression, it, isReferenced)
MyLog : {
_toJavaStatement(expr, it, isReferenced)
default : super.doInternalToJavaStatement(expr, it, isReferenced)
def void _toJavaStatement(MyLog expr, ITreeAppendable b, boolean isReferenced) {
val it = b.trace(expr, false);
if (expr.getExpressions().isEmpty())
return;
if (isReferenced)
declareSyntheticVariable(expr, it);
newLine().append("if (1==1) {//trace is enabled")
increaseIndentation();
openPseudoScope();
val expressions = expr.getExpressions();
for (ex:expressions)
if (ex == expressions.last)
internalMyLogToJavaStatement(ex, it);
if (isReferenced) {
newLine().append(getVarName(expr, it)).append(" = ");
internalToConvertedExpression(ex, it, getType(expr));
append(";");
} else
newLine.append ('''System.out.println ("logging in "+MN+" -> "«FOR varName :expressions.map[ex|ex.getVarName(it)]»+«varName»«ENDFOR»);''')
it.closeScope();
it.decreaseIndentation()
newLine().append("}");
def void internalMyLogToJavaStatement (XExpression expr, ITreeAppendable it)
switch (expr)
XStringLiteral : declareFreshLocalVariable(expr, it, [append('''«_toJavaExpression(expr, it)»''')])
XAbstractFeatureCall:{
declareFreshLocalVariable(expr, it, [append('''«featureCalltoJavaExpression(expr, it, true)»''')])
default : internalToJavaStatement(expr, it, true)
Now I had to change my grammer to add the new Literal
XPrimaryExpression returns xbase::XExpression:
XConstructorCall |
XBlockExpression |
XSwitchExpression |
XFeatureCall |
XLiteral |
XIfExpression |
XForLoopExpression |
XWhileExpression |
XDoWhileExpression |
XThrowExpression |
XReturnExpression |
XTryCatchFinallyExpression |
XParenthesizedExpression|
MyLog;
Can anyone mark this as solved?
FUDForum. Page generated in 0.06974 seconds
