Home » Archived » Hudson » Cron thread throw an exception
Cron thread throw an exception [message #1273737] Thu, 20 March 2014 09:14 Go to next message
Today I removed the errors from logs, unfortunately I can't deal with one of the warnings
Mar 20, 2014 2:10:57 PM hudson.triggers.Trigger$Cron doRun
WARNING: Cron thread throw an exception
com.google.common.util.concurrent.UncheckedExecutionException: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.NullPointerException
        at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2263)
        at com.google.common.cache.LocalCache.get(LocalCache.java:4000)
        at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:4004)
        at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4874)
        at hudson.model.TopLevelItemsCache.get(TopLevelItemsCache.java:78)
        at hudson.model.LazyTopLevelItem.item(LazyTopLevelItem.java:144)
        at hudson.model.LazyTopLevelItem.hasPermission(LazyTopLevelItem.java:271)
        at hudson.model.Hudson.getItems(Hudson.java:1303)
        at hudson.model.Hudson.getItems(Hudson.java:223)
        at hudson.model.Hudson.getAllItems(Hudson.java:1367)
        at hudson.triggers.Trigger.checkTriggers(Trigger.java:228)
        at hudson.triggers.Trigger$Cron.doRun(Trigger.java:185)
        at hudson.triggers.SafeTimerTask.run(SafeTimerTask.java:43)
        at java.util.TimerThread.mainLoop(Timer.java:534)
        at java.util.TimerThread.run(Timer.java:484)
Caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.NullPointerException
        at hudson.model.Hudson.getItem(Hudson.java:2175)
        at hudson.model.Job.onLoad(Job.java:329)
        at hudson.model.AbstractProject.onLoad(AbstractProject.java:325)
        at hudson.model.BaseBuildableProject.onLoad(BaseBuildableProject.java:91)
        at hudson.model.TopLevelItemsCache$1.load(TopLevelItemsCache.java:64)
        at hudson.model.TopLevelItemsCache$1.load(TopLevelItemsCache.java:57)
        at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3599)
        at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2379)
        at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2342)
        at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2257)
        ... 14 more
        at hudson.model.Job.getCascadingJobProperties(Job.java:694)
        at hudson.model.Job.getAllProperties(Job.java:849)
        at hudson.model.Job.onLoad(Job.java:362)
        ... 30 more
any idea?
Re: Cron thread throw an exception [message #1273801 is a reply to message #1273737] Thu, 20 March 2014 11:03 Go to previous messageGo to next message
Which version of Hudson are you using?
Re: Cron thread throw an exception [message #1274245 is a reply to message #1273801] Fri, 21 March 2014 03:24 Go to previous messageGo to next message
Hudson: 3.1.2 (via tomcat6)
OS: Ubuntu
[Updated on: Fri, 21 March 2014 03:44] by Moderator
Re: Cron thread throw an exception [message #1697199 is a reply to message #1273737] Tue, 02 June 2015 07:47 Go to previous messageGo to next message
By any chance do you remember how you fixed it as I am getting similar issue:
at hudson.triggers.Trigger.checkTriggers(Trigger.java:263)
at hudson.triggers.Trigger$Cron.doRun(Trigger.java:215)
Re: Cron thread throw an exception [message #1698330 is a reply to message #1697199] Sun, 14 June 2015 01:12 Go to previous message
I recently ran into this problem, too. None of my cron-scheduled builds would run because a few of them were crashing the cron trigger. The offending builds were not even scheduled to run periodically, per se, but they did have the Github Pull Request Builder plugin enabled.
To find the offending jobs, I turned on logging for "hudson.triggers" using the instructions:
wiki.jenkins-ci.org/display/JENKINS/Logging
I set the log level to "ALL" and was able to quickly see the job(s) that were causing the exception.
I edited those jobs to remove the Github Pull Request Builder flag in the "Build Triggers" section.
Once the logs looked clean, my cron jobs started triggering again!
Previous Topic:Internal Server Error with the Google Login Plugin on Hudson 3.3.0-RC1
Next Topic:Perform testing (protactor / selenium) with jenkins with 1024x768 resolution
Current Time: Sun Jul 20 22:36:34 EDT 2025
Powered by FUDForum. Page generated in 0.48407 seconds
