Home » Eclipse Projects » GEF » SnapToHelper problems.
SnapToHelper problems. [message #127396] Thu, 15 April 2004 03:42 Go to next message
Originally posted by: eostroukhov.hotmail.com
SnapToHelper is built around Visitor GOF pattern so it inherits major
weekness of that pattern - whenever you need to add a new request type you
have to add respective methods to each SnapToHelper implementation.
In our project we have several requests that would enjoy snapping to the
grid/guides/whatever bat they are not direct siblings of the move, resize or
create requests. I.e., we have a special "table" element that fills its
parent horizontaly so it should only have its left and right margins
snapped. The problem is that I don't see how can I derive the request from
the three snapable requests.
What I want to offer is to discuss some general interfaces for the requests
that can be snapped. In our project I see following request types:
1. Rectangular request - it's similar to ChangeBoundsRequest
2. Point request - i.e. like DropRequest implementation.
Maybe it is possible to define the request types and special interfaces so
new tools developers will be able to leverage the reuse of the snapping to
their custom requests? I can start implementing snapping in existing
strategies as soon as the interfaces will be agreed.
Eugene
Re: SnapToHelper problems. [message #127402 is a reply to message #127396] Thu, 15 April 2004 04:22 Go to previous messageGo to next message
To make my point clear - I've added method int
snapLocationRequest(LocationRequest request, int snapOrientation); and
implemented it for the SnapToGuides - this allows me to snap column resize
request, drag line end request, can allow to snap when dragging bend points,
etc.
So I guess, if we will define correct request types there will be some 2-5
generic methods instead of snapCreation..., snapResize..., snapMove... (I
consider them too narrow for the broad range of the products to be developed
using GEF)
Eugene
"Eugene Ostroukhov" <eostroukhov@hotmail.com> wrote in message
news:c5lduv$1mr$1@eclipse.org...
or
requests
> Best regards,
> Eugene
Re: SnapToHelper problems. [message #127533 is a reply to message #127396] Thu, 15 April 2004 15:26 Go to previous message
Oh. I didn't even realize that.
There are several issues involved with the primary types of snapping we
wanted to support. We should definitely try to make the included methods as
generic as possible, and even consider adding generic methods which aren't
used but would be useful in the cases you describe. Open a bugzilla and
attach any code you have. Thanks!! Be sure to pay attention to zooming
complexities, and also use of HandleBounds instead of bounds.
or
requests
> Best regards,
> Eugene
Previous Topic:Decorators in GEF
Next Topic:NullPointerException in GraphicalEditor
Current Time: Wed Sep 03 14:01:17 EDT 2025
Powered by FUDForum. Page generated in 0.02842 seconds
