Home » Eclipse Projects » Eclipse Platform » My Search Result does not show properly!!!
My Search Result does not show properly!!! [message #123806] Sun, 07 September 2003 16:16 Go to next message
Originally posted by: apatil.block.spam.syndera.com
Hi NG,
I am new to eclipse. And I am trying to do a search of my own. I can get my
search page to come up.
Problem ::
I am adding th matches to the search but the list of the matches does not
show up.
Here is what I am doing
First search : nothing shows up (only the search view is activated)
Second search : nothing shows up , but the search history is suddenly
populated with both my searches (this one and previous) , the current search
is checked , but still nothing is visible in the view as such.
I switch to the results of my first search and NOW it shows up, again I
switch to my second search results and it shows up.
I do a third search, again the same thing happens, the history shows third
search as checked , but no match(s) listing. but switching around the
history brings it up.
I will paste the code of the search runnable here
ISearchResultView searchResultView = SearchUI.getSearchResultView();
searchResultView.searchStarted(
null,
"Singular Search #"+count+" found single match",
"Plural Search #"+count+" found {0} matches",
null,
"com.syndera.architect.ui.search.repositorysearchpage",
new MyLabelProvider(),
new MyGoToAction(),
new MyGroupByKeyComputer(),
new MyRunnableWithProgress());
count = RepositorySearchPage.count;
System.out.println("Count is "+count);
monitor.beginTask("Searching Repository",count);
IWorkspaceRoot root = ArchitectPlugin.getWorkspace().getRoot();
for (int i = 0 ; i < count+1 ; i++){
try {
monitor.subTask("Found "+i);
RepositoryDerivedResource derivedResource = new
RepositoryDerivedResource(root);
searchResultView.addMatch("some desc
" +count,derivedResource,derivedResource,derivedResource.creat eMarker(IMarker
..MARKER));
Thread.sleep(2000);
monitor.worked(1);
} catch (CoreException e) {
e.printStackTrace();
monitor.done();
searchResultView.searchFinished();
count++;
Second Question:
Can I drag a search match from the search view , onto a editor , similar to
how I can drag "Tasks" from the task view
Pls help,
I am at my wits end trying to get the search to work properly...
Thanks In Advance
Anand Patil
Re: My Search Result does not show properly!!! [message #127357 is a reply to message #123806] Thu, 11 September 2003 09:16 Go to previous message
Originally posted by: daniel.megert.gmx.net
Make your search operation to be a WorkspaceModifyOperation (see
TextSearchOperation as an example).
HTH
Dani
Anand Patil wrote:
>Hi NG,
>Problem ::
>show up.
> null,
> null,
> new MyGoToAction(),
> try {
>.MARKER));
> Thread.sleep(2000);
> monitor.worked(1);
> monitor.done();
> count++;
>Second Question:
>Pls help,
>Thanks In Advance
>Anand Patil
Previous Topic:Warning to do string == "compare"
Next Topic:Handling of RuntimeExceptions
Current Time: Sun Jul 27 06:41:49 EDT 2025
Powered by FUDForum. Page generated in 0.07336 seconds
