ZEST: Register GraphViewer as a model listener [message #1273156] |
Wed, 19 March 2014 12:07  |
this might be a stupid question but I'm new to ZEST and GEF.
THe following use case: I have my own RCP application where I integrated my own GraphView as a ViewPart.
It is added via an extension point, so (I think) I have no control about the instantiation of my view and its containing GraphViewer instance (I might be wrong here).
What I want to do is to show the view next to an Xtext editor where the user can manipulate a model. When the user saves the changes, I have a hook from Xtext to be notified if the new model should be build (by overriding the BuilderParticipant that invokes the generator of my language).
The problem is that, from within my Xtext code, I see no clean chance to access the ViewPart and/or GraphViewer instance that was created during eclipse startup. I know that I could ask the workbench for the view part via its id but this seems unnecessary complicated.
Isn't the described use case quite popular (that you want to register a viewer to a model) but you don't know about the model when eclipse instantiates the view? What's the kook here?
Thanks.
Re: ZEST: Register GraphViewer as a model listener [message #1274197 is a reply to message #1273225] |
Fri, 21 March 2014 01:26  |
Okay, here is my solution so far which I think is decent enough to share:
I work with Xtext SDK 2.5.0.v201312110906 and GEF4 Zest SDK 0.1.0.201403150206.
1. Create a subclass of ViewPart and give it a GraphViewer object
2. Mark this class with the Singleton annotation of Guice
3. Initialize your viewer in the your override of createPartControl (refer to this tutorial if necessary). However, I don't set the input however, since I don't have a model at startup time.
4. Add your view the views extension point of your DSL.ui project
5. Make sure that it is instantiated using your ExecutableExtensionFactory, sth like this:
<extension point="org.eclipse.ui.views">
<view class="[YOUR LANGUAGE].ui.ExecutableExtensionFactory:[YOUR LANGUAGE].ui.views.[YOUR VIEW]"
id="[AN ID]"
name="SOME NAME"
restorable="true">
</view>
</extension>
6. Add a "refresh" method to your ViewPart implementation, sth like this, where you pass the model as a resource or however you like:
def refresh(MyGraphModel flatList) {
Display.^default.syncExec [ |
graphViewer.setInput(flatList)
7. Subclass Xtext's BuilderParticipant and inject your singleton graph viewer:
@Inject
MyGraphView graphView
override protected handleChangedContents(Delta delta, IBuildContext context,
EclipseResourceFileSystemAccess2 fileSystemAccess) throws CoreException {
val resource = context.resourceSet.getResource(delta.uri, true);
if (shouldGenerate(resource, context)) {
try {
if (graphView != null && graphView.graphViewer != null) {
graphView.refresh(resource.m2m)
} catch (RuntimeException e) {
if (e.cause instanceof CoreException) {
throw e.cause as CoreException
throw e;
super.handleChangedContents(delta, context, fileSystemAccess)
Note that I call the super-implementation after my graph refresh to avoid unresolved objects in the resource.
8. You need to add your View to the perspectiveExtensions extension point if you want to show it right at start up.
9. Make sure that you've added bindings for your BuilderParticipant and ViewPart to your UI Module so Guice knows what to create.
If I haven't forgotten anything, this should lead to a graph view that "listens" to updates in your Xtext Editor.
Once I have a decent m2m transformation to show a nice graph I upload a video.
Have fun!
[Updated on: Fri, 21 March 2014 01:29] by Moderator
FUDForum. Page generated in 0.10973 seconds
