Home » Newcomers » Newcomers » Java Reflection problem in Eclipse?
Java Reflection problem in Eclipse? [message #1273091] Wed, 19 March 2014 09:39 Go to next message
I'm working on Eclipse plugin development. At one place, I need to load classes from external jar and read its methods annotations. Unfortunately, when I call method.isAnnotationPresent(MyAnnotaion.class), it return false all the time (I run/debug the plugin from Eclipse). If I run the snippet from JUnit (from Eclipse), it works fine.
Any suggestions?
Re: Java Reflection problem in Eclipse? [message #1273125 is a reply to message #1273091] Wed, 19 March 2014 10:58 Go to previous message
I'm sorry for disturbing. The problem is solved. My problem was that MyAnnotation was in jar outside eclipse and I had to add Eclipse's classloader into myJars classloader...
Re: Java Reflection problem in Eclipse? [message #1273127 is a reply to message #1273091] Wed, 19 March 2014 10:55 Go to previous message
Artem,
What do you mean exactly by "load classes from external jar"? Is that
jar a library specified in the MANIFEST.MF of a bundle?
> Any suggestions?
Previous Topic:Licease transfer/upgrade?
Next Topic:Trying to work on multiple projects
Current Time: Mon Jul 21 11:29:12 EDT 2025
Powered by FUDForum. Page generated in 1.00236 seconds
